I currently have an Onkyo TX-NR509 and while it's been a good little receiver I'd like to upgrade to something a little more powerful with more features. I have a few requirements. It needs to be at least 7.2, convert composite / component to HDMI and have an auto config similar to Audyssey and at least 100w per channel (preferably higher). The more HDMI inputs the better as well.
My speaker setup is:
Polk Audio CS2
Polk Audio Monitor 70's
Polk Audio Monitor 30's
(Will add Monitor 40's to complete the 7.x setup)
BIC F12
They aren't the most high end speakers but I do believe they will benefit from a little more power (I do not plan on using external amps with this setup).
So giving a price range of $400 - 700, possibly a little higher if it will really benefit the HT, what would be a good receiver? I'm open to different brands but I've used Onkyo in the past. I was eyeballing the Onkyo 809 which can be had for a little over $600.
Polk Audio CS2
BIC F12
