Hello all, I am trying to hook up a Behringer EPX3000 amplifier to a pioneer sc 68 amp Subwoofer output. The output on the Pioneer is RCA. I am using a TC SOUNDS LMSR 15 Sub that I have built a custom enclosure for. I have the option to use RCA on the Behringer Amp,that said I have read in other posts that the input would be lower than a connection made by XLR. I have read about a device made by Samson that ups the input voltage to the amp. My question is should I be connected with RCA and the gain turned all the way up? or should I purchase some kind of gain adjuster? XLR to RCA? I need a bit of basic explanation.Thanks for the help.
AVS › AVS Forum › Audio › DIY Speakers and Subs › Behringer EPX3000 best connection to Receiver Sub out
AVS Top Picks
post #2 of 20
1/2/13 at 9:44am
post #4 of 20
1/3/13 at 1:47pm
post #5 of 20
1/3/13 at 2:14pm
post #6 of 20
1/3/13 at 2:52pm
post #7 of 20
1/3/13 at 7:24pm
post #9 of 20
1/4/13 at 4:09am
post #11 of 20
1/4/13 at 10:59am
post #12 of 20
1/5/13 at 5:12am
post #13 of 20
1/5/13 at 10:00am
post #15 of 20
1/6/13 at 7:43pm
post #17 of 20
1/7/13 at 10:26am
post #19 of 20
1/7/13 at 1:12pm
AVS Top Picks
The EPX is a killer amp. If you bought it new, it should give you DECADES of good playback. perhaps try another cable? Are you using a direct RCA to RCA cable at the moment?
