I bought the new Harman Kardon AVR 700 model. Can anyone tell me how to make it power off/on using my cable poviders (COX) remote?
I entered the correct code for HC but when I try to use the cable providers remote to power off if goes into standby mode... not off. When I power on it does not work at all. The tech support folks at COX say "If it powers down to standby mode the correct code is being used, however, if it does not power on then call HC. They cannot help beyond providing the code."
If anyone is considering purchasing a Harman Kardon product you should know 1st that is extermely difficult to get their technical support people on the phone.
Any suggestions?
Any suggestions?
