AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Ceiling Mount for Sony Projector
post #1 of 2
Im a little confused. I want to mount my projector to the ceiling. I am currently looking at the Chief RPA020. I was going to "flush" mount this projector as close to the ceiling as possible. If I don't use an adjustable extension column do I need another plate that mounts to the celing? Chief's website isnt 100% clear, at least not to me.
I do understand that if I want to drop the projector down a couple inches I need a Joist celing mount, extension arm and the mount for the projector.
post #2 of 2
The RPA series is designed to connect to some sort of 1 1/2" threaded column. Your best hope for minimal additional height added to the mounting hardware would be one of Chief's ceiling mounting plates and a 1 1/2" threaded nipple from your local hardware store. Most of the nipple would screw into the ceiling plate and RPA mount, only adding another .5-.75" besides the ceiling mounting plate thickness.
Just keep in mind you need to be able to reach the set screws for the 3 axis adjustments, might require an extra long phillips screwdriver.
Edited by weaselfest - 1/2/13 at 3:16pm
