AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Can I put the Epson 5020UB in a cofee table???
post #1 of 3
So I am new to the Projector game and I am in a rental for about a year so I am limited by my options but I was wondering if I could put my projector in something like this? I would just open one (or two if needed because of heat) doors to hide the projector. Would this work? Also, I was just going to by an inexpensive pull down screen on ebay but was curious if you had any recommendations under $200 in the 100 inch range? Thanks guys. Based on my research this seems like a great all around projector. The top also lifts up on this table.
Jim
post #2 of 3
u mean inside ?
never put the projector inside anything .
it gets very hot and it needs air circulation
post #3 of 3
As long as your projector has lens shift you should have no problem at all. With non lens shift projectors the height of the table must be just right but when you have lens shift this is not a problem
