DVD Player In Media Closet
post #1 of 5
Is there anyway to connect one DVD player to 2 different tvs? My current media closet has 2 seperate cable boxes connected to my two tvs via component cables. I had one tv hooked up to DVD player via a reciever.
post #2 of 5
Easiest way is a component video matrix switch. There may be cheaper models, I just searched quickly:
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=314788&Q=&is=REG&A=details
That will allow you to connect 4 sources to 2 TVs...
How are you handling remote control now? IR repeater or RF remote - you'd want to be able to switch sources and control the boxes and DVD player.
Jeff
post #3 of 5
I'm using an IR remote(MX 900)...maybe I would be better served to buy another DVD player?
post #4 of 5
Well, depends on what you're trying to accomplish. You'll need two component video switches (Monoprice has great units for $20/each) to select between the cable box and the DVD player(s) for each TV. Plus a DVD player. If you can get a 4x2 component matrix for not much more money than that total, you'd have a better solution...
There's lot of component gear around - check eBay, too.
Jeff
post #5 of 5
thanks for the great advice...much appreciated
