Hi,
I recently took delivery of my new Klipsch RW-12d subwoofer for my home theater buildout. Next on the list are a projector screen and a set of good surround speakers from Ascend Acoustics, but for now I'm projecting on a wall and using a cheap pair of RCA 2-way stereo speakers with 5.25" main drivers. I have no center or surround. Everything is connected through my Denon AVR-2313ci.
Anyway, I wanted to run Audyssey with the subwoofer connected, run some tests, and watch a few bassy movie scenes to see how it all works together. Audyssey ran fine, setting my front speakers to "small" and the front crossover to 60hz; basically what I expected. The "ring drop" scene at the beginning of Lord of the Rings was a good initial test. Then, just to see what it could really do, I downloaded this MP3:
http://www.pyon.fr/hcfr/Bass%20Test%20Tones/Bass%20Test%20Tones%20-%20Linear%20Sweep%2060hz%20-%205hz.mp3
As the title indicates, it's a linear sweep from 60hz down to 5hz, and it really shows off what the Klipsch can do. It's fun to listen to the air rushing in and out of the port at the bottom of the range.
However, I noticed that the main drivers on my front speakers are also getting signal all the way down to 5hz as well, and it's going to tear the surrounds to shreds if that keeps up (and I keep playing super-deep bass on constant repeat with the volume cranked up, which I won't). Given the crossover setting, I expected activity from the fronts only at the very top of the sweep and tapering off sharply.
Why isn't my receiver honoring the crossover setting? Suggestions? Thoughts?
However, I noticed that the main drivers on my front speakers are also getting signal all the way down to 5hz as well, and it's going to tear the surrounds to shreds if that keeps up (and I keep playing super-deep bass on constant repeat with the volume cranked up, which I won't). Given the crossover setting, I expected activity from the fronts only at the very top of the sweep and tapering off sharply.Why isn't my receiver honoring the crossover setting? Suggestions? Thoughts?
