I posted this earlier in a tv thread but figure this is a better place to ask the question. I plan on mounting an 80 inch tv with the Sanus VMPL3. The question I have is when I attach the TV to the mounting arms can you use different holes in the arms to have the TV sit higher or lower. As an example if the mounting bracket is lag bolted on the wall and in the future I want to lower or Raise the TV a couple of inches can I do it by just moving the TV up and down in the different holes on the arms and not having to take the plate off the wall to re lag bolt it up or down. Thanks?
AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Wall mount question
Wall mount question
AVS Top Picks
Pros:“Excellent value for the price - Paid $79.95 at Frys.”“Absolutely stunning 24p play back. Networked Apps are flawless (wired). Very customizable. Unbelievable DLNA capability. Ability to skip the unskippables in a DVD. Overall professional onscreen GUI. Audio Quality is surprisingly very good. Upscaling as a customizable, menu driven item. Very Apple-esque.”
