AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › How do you hook up a powered sub and a non-powered sub?
post #1 of 7
Hi all, I have a Sony SA-WM20,(pic), hooked up to my Denon AVR-1513, it's a powered 8" sub and I also wanted to hook up a Sony non-powered 12" sub, what would be the best way to do this without another amp? The powered sub has "speaker outs" can I get a powered signal from there to the 12" Sony? THANKS!
post #2 of 7
You need another amp to power the passive sub.
No.
post #3 of 7
There is no other way to tap into the power that is already there?
post #4 of 7
Not that I'm aware of. AFAIK, a powered sub's amp powers only the sub itself - the power can't be "shared" with other (passive) subs.
post #5 of 7
You'd need an another amp to power the passive one. Use a Y splitter (RCA) with one going to the powered sub and another going to the amp and eventually to the passive subwoofer. The outs on your powered subwoofer wouldn't be the ones you want to use for your passive sub. Those are for if your L/R speakers.
post #6 of 7
Check this link, I had a similar conversation about this topic. You might find it useful.
http://forums.audioholics.com/forums/subwoofers/83490-possible-clipping-issue.html
post #7 of 7
The speaker outputs would use power amp level inputs and send a high level signal to the speakers. So they don't and could not use the sub's mono amp to provide stereo output and besides they are designed to keep the subwoofer frequencies out so they aren't an especially good power source for a sub
