AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Headphone amp question
post #1 of 9
I am looking for the best headphone amp to put between my PSX to my Grado SR125i. Is Grados amp ( http://www.gradolabs.com/page_headphones.php?item=7882e729321fad6256d8d77c0629dbb4 ) worth the price? I have around a $400 budget.
post #2 of 9
The Grado amp is one of the most overpriced pieces of gear I've ever seen. Google an image of the RA1 with the top removed. I love Grado cans, but that amp eek.gif
There are many less expensive products out there that will perform much better. Head over to head-fi.com for a lot of info.
That said, the Grados are very efficient and many not benefit much if at all from an amp.
post #3 of 9
post #4 of 9
How do you suggest I get the best sound from the PSX to those headphones? A nice and simple question.
post #5 of 9
How do you suggest i get the best sound form that PSX of mine to those headphones? Thanks for the advice thus far.
post #6 of 9
What do you have for audio out from your PSX?
post #7 of 9
It has RCA out.
post #8 of 9
http://deutschermanfred.de/en/
check this site out for info on the PSX, its going to be my winter project.
post #9 of 9
It has RCA out.
Then you simply use the RCA out to the in on a Headamp unless you choose to use a DAC in between the Amp and PBX.
