Hello. I have a Mits HC5000 projector with a 92" screen. I want to upgrade to 106 or 110". The projector is at 11 ft from the screen and is mounted to the ceiling. The room is a dedicated theater room and light is completely controllable. Dimensions are roughly 9', 14' by 24' long.
What are some screen choice options?
Do I need a super expensive screen since light is very controlable?
Screen Innovations Black Diamond? Da-Lite Cinema Vision?
Thanks for your help?
