Hi all,
Firstly, apologies if this has been answered. I have searched and could not find a definitive answer.
Setup:
Onkyo TX-NR616
Panasonic 50" Plasma connected to HDMI main (downstairs)
Crappy Bush 32" connected to HDMI Sub (upstairs)
I have HDMI Control ON
I listen to the audio downstairs (Panasonic) through my surround sound, and the amp power and volume are controlled from TV remote.
I want to be able to watch TV upstairs (Bush) on the TV speakers.
I turn off the Onkyo and it goes into passthrough for a minute or so (to HDMI Sub), then stops, giving a blank screen.
If I turn OFF "HDMI Control", and set "HDMI Through" to the correct source, then it works fine on the upstairs TV. But it means I need to go into the menus to set "HDMI Control" on again when I want to watch TV downstairs (and control the volume and power from the TV remote).
Does anyone know if it is possible to keep HDMI Control on, but still have the Onkyo correctly go into Passthrough on HDMI Sub when the amp is turned off?
Thanks in advance!
Setup:
Onkyo TX-NR616
Thanks in advance!
