AVS › AVS Forum › HDTV › HDTV Technical › Daytona Beach, FL: Attic antenna questions, got my tvfool and so on
post #1 of 4
Tvfool, ran at 20 feet. http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3dc84f803f5a3b0b
I live in a deed restricted community. It is my understanding that I can basically do whatever I want with regards to a tv antenna but I'd like to avoid disdain from the neighbors.
My preference would be an attic or indoor antenna. I'm not quite sure if I need VHF in addition to UHF. I'm thinking I don't need a preamp. I would also be open to suggestions of some good coax cable, if it matters.
I appreciate any help you guys can offer.
post #2 of 4
The deed restrictions probably violate federal law....
If you want WESH, pick a small UHF/high-VHF combo for the Orlando locals. The Antennas Direct ClearStream 2V is really compact and unobtrusive. Otherwise,an RCA ANT-751 or an AntennaCraft HBU-22 or Winegard 7694 would all be suggested.
Point whatever you get to the south for the Orlando major stations.
post #3 of 4
This is helpful, thank you. Should I bother with a preamp?
post #4 of 4
You don't need nor should you use an amplifier.
  Back to Forum: HDTV Technical
