AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › DNS-323 videos not showing up on Samsung AllShare
post #1 of 10
I have turned on the UPNP AV mode and I actually used iPhone 8player app that can read the directory and play the files, however the ES6100 AllShare sees the DNS-323, but cannot see any file name at all, saying "No media files detected on the device" or something like that. Any suggestion?
Ernest
post #2 of 10
Ernest
Probably the ES6100 doesn't support the type of files you've got.
post #3 of 10
I have that suspicion as well - I do have a variety of files but tonight I'll put much more variety on it and see. Maybe I'll have to get a WD Live TV : ( It's such a shame - my TV and my DVD players, both can do DLNA but very limited in what files it support.
post #4 of 10
Ah - I tried and still nothing! Another data point: I've plugged in my external HD via USB to the TV and it can play those files, which are also on the DNS-323 and none is showing up! I'm at lost on what else I can do. Call Samsung?
post #5 of 10
Samsung have their own custom version of DLNA, it's not compatible with UPnP & some DLNA servers unless they have a specific profile applied to the IP of the TV.
The easiest thing to do is get a WDTV Live, it's cheaper than replacing the NAS which can run alternate UPnP/DLNA servers which have Samsung profiles. There are some tutorials out there on the web for hacking a DNS-323 and getting Twonky or Serviio on it which could work. One last thing make sure the firmware on the NAS is up to date too, this includes the media server profiles for Samsung if D-Link have them.
Edited by Alx330 - 1/5/13 at 5:19am
post #6 of 10
Thanks so much for your help - I'll update the firmware to see if it helps. I'm kind of surprise that I cannot find anybody mention this 'problem' as DNS-323 and Samsung TV are fairly common. Costco had WD TV on sale couple weeks ago I'm not sure if it's still the case!
post #7 of 10
hi, i have been using dns323 with my samsung C8000 and it works fine,
see if this helps,
on your samsung tv, make sure the all share setting for the dns-323 ip address is set to enable instead of denied
post #8 of 10
More clues more questions...
Hey Jiggariz.... I checked and it seems the DNS323 is not even listed under AllShare Settings! Actually that stupid TV only shows 192.168.0.1... (doesn't show 101) because it's too long. How do I get it listed there?
Also, I notice that when I select input, DNS shows up but the icon has a little question mark there.
post #9 of 10
emm, just to check is your tv and dns323 connected to the same modem? try pinging from your pc to your tv's ip address, really cant think why its not working, will revert back if i can think of any
post #10 of 10
Things can change between generations Samsung have become much more aggressive on their custom DLNA with the E series, I too have a C series model and it doesn't work with all servers, UPnP only servers seem to have the most trouble.
If the DNS-323 has Samsung E series compatibility then it must be some other networking issue. DLNA is such a weak standard the chain can break in many places, it could be bugs in the router or firewall interfering with the traffic.
Try starting with these settings
Router with IP of 192.168.1.1
DHCP range 192.168.1.2 to 50
UPnP enabled on the router
IGMP multicast enabled on the router
Router firmware up to date
Re-run the network setup on the Samsung after the above and try connecting to the NAS.
