AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What models are back lit local dimming?
post #1 of 8
I am trying to research a new TV and am finding it hard to see what models are back lit LED with local dimming. You would think that the manufacture web sites would state that feature.
I am looking mainly in the Samsung & Sony lines
I see now that the Sony is only the XRB line, they are too large and too high priced, so Sony is out.
post #2 of 8
I think you will find that only the high end Sony panel and the Sharp Elite panels have backlit tech with local dimming. Some of the vanilla Sharp panels are also backlit but no local dimming as far as I know. It seems most are turning to the edge-lit panels as I assume they are cheaper to make.
1000
post #3 of 8
Just to note that there is a difference between full array LED and direct LED (backlit LED). Full array LED is the fancy kind that high end Sony and Sharp Elite use.
Direct or backlit LED is like regular LCD except with LED instead of CCFL lighting. Direct LED is the thick kind and is usually cheaper than edge lit LED.
All three flavors may or may not come with local dimming.
post #4 of 8
in 2012 LG had two local dimming led nano TV'S .the LG LV9500 and LM9600. The LV was active 3D and the LM9600 has passive 3D.
post #5 of 8
Thanks for the replys. Would be nice if they just gave the real specs on these thing, guess most people just don't care when they get them.
Any of the Samsung models that are NOT edge lit and have local diming?
post #6 of 8
The Vizio M3D651SV aslo has local dimming, though it is an edge lit LED.
Rick
post #7 of 8
There is Full Array Local Dimming and there is Edge Lit Local Dimming
http://reviews.cnet.com/2795-6482_7-399.html
There are no Samsung Full Array Local Dimmings any more , last one was the 2009 UNXXB8500.
In general the Full Array Local Dimmings are the most expensive LEDs (only 4K Edge Lit LEDs are more expensive)
2012 Full Aray Local Dimmings, most of them
http://www.avsforum.com/t/1365130/full-array-led
older full Array Local Dimming list and benefits
http://www.avsforum.com/t/1245172/unofficial-local-dimming-list-and-benefits
post #8 of 8
Doesn't look like it. From what I saw at Amazon, Samsung offers ES and EH series HDTVs. ES is the edge lit LED (thin kind). EH is the direct (backlit) LED (thick kind) and is the lower line.
Local dimming is only offered on upper ES series.
