Surprisigly, I've had interest in audio calibration from considerably less than 1 in 10 customers interested in video calibration.
The main reason is that calibrating audio requires flexibility in where you place each speaker, especially the subwoofer AND in where you place the listener(s). If the room pretty much dictates where the TV or projector/screen have to be and the spouse limits where you are allowed to move the seats (and screen or TV), there's not a whole lot audio calibration can do other than add room treatments and that's often also limited by SAF (spouse acceptance factor).
Sometimes much more can be done if the subwoofer offers many tuning options like most of Hsu's VTF series subs... they have 2 ports with 3 possible configurations (2 open, 2 closed, 1 open/1 closed) along with adjustable Q. You can do a lot with that subwoofer without moving it, though if you CAN'T move it, there are likely to be room issues that can't be corrected. I've been able to get VTF series subs within +/- 2.5 dB from 16 Hz to 80+ Hz using just the adjustments available in the subwoofer. But it can take 8 hours to explore all the combinations of settings.
Done right, audio calibration is TIME CONSUMING. You have to find the best locations for each speaker and for at least 1-3 seats. Once you know that, you can place the screen or TV appropriately. Then you get into fine tuning using the tunable capabilities of the speakers (if any) and subwoofer (if any).
If you are there doing a video calibration for 2D and 3D with full grayscale and color controls, you could put 5 to 6 hours into the video calibration and audio calibration can add another 4 to 24 hours of work so it's not likely to get done well in a single visit with a video calibration unless it was a very simple and quick video calibration.
If you plan to do audio calibration in a new room, you want the room done enough that any finish work will be things that don't affect acoustics, but you don't want the room SO finished/completed that you have no flexibility for adding room treatments if needed. And room treatments can add significantly to the cost of audio calibration. I've done some 15-25 hour audio calibration jobs at $55/hr with another several thousand dollars in room treatment products of one type or another. It can be a whole other experience compared to video calibration. If a customer is willing to spend, say, 2 more hours or labor on audio calibration and they have Audyssey or something like that in their system, there's going to only be a limited amount of work/changes that can be done in a couple of hours. I liken it to getting your car washed, but only the bottom 1/3 of the car, not the whole thing. And (very common) limitations about where seats and speakers and TV/Screen can be moved will always compromise results and make improvements more difficult and time consuming.
BTW -- when you click the link to "Buy online" to see what the cost is you get a server error that says the page does not exist.
Edited by Doug Blackburn - 1/4/13 at 10:22pm
