AVS › AVS Forum › Display Devices › Screens › Screen Recommendation
post #1 of 2
I wanted to get some feedback on screens for a decent price.
- 120"
- Completely light controlled room so 1.0 gain????
- Wall mounted
- Deep matte purple walls (almost black)
- White ceiling, but possibly will put some fabric etc to darken it.
- Using it with an Epson 3010
- $300 max unless there is reason to go above.
Should I got with Jamestown or an Elite Sable:
http://www.jamestownhometheaterscreen.com/120_screenDiagonal.html
http://www.amazon.com/Elite-Screens-ER120WH1-Projection-Screen/dp/B00366S0UW/ref=sr_1_1?ie=UTF8&qid=1357319928&sr=8-1&keywords=elite+screen+120+sable
Also, how much of a price difference and quality difference are AT screens? Can I get the same quality from AT vs non-AT? I don't have to go AT but I like the idea of my center being in the middle of the screen for more accurate sound.
Edited by mginster - 1/4/13 at 9:19am
post #2 of 2
I'm convinced that this is the same screen that I bought from htdepot.com about 2 years ago for close to twice the price. It has been excellent for me. Never has had any wrinkes or waves and is quiet. I don't know how you could beat it for a budget screen. I use it with my Viewsonic Pro8100 and for the last year my Epson 3010. JMHO
http://www.amazon.com/FAVI-HD-120-16-120-Inch-Projector/dp/B0026DTP2S/ref=sr_1_4?ie=UTF8&qid=1357394334&sr=8-4&keywords=favi+projector+screen
Hope this helps. Good luck!
Ed
  Back to Forum: Screens
