AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha Receiver RX-A720 question
post #1 of 7
Hi, I'm new here but have been lurking for quite some time. At the end of last year I purchased the Yamaha RX-A720 and love it. Recently my Dad was in town and when I wasn't home, he was playing with the receiver and some how changed a setting and it's driving me crazy. When I boot up the receiver it use to always default to Scene2 TV and the sound would work fine. Now, when I turn on the receiver and the TV, it goes to TV Viewing but then defaults to AUDIO1. After I hit the TV SCENE button again, it will go to TV Viewing, sound will work and then for a 2nd time, go back to AUDIO1. I'm not sure what I'm missing but it's really bugging me that I can't figure out how to get it back to just turn it on without it going to AUDIO1 twice before working properly. Hopefully some can give me a hand, it would be much appreciated. Thank you.
Ed
post #2 of 7
Set the input and surround mode you want using either the remote or front panel. Hold down Scene2 TV on the front panel of the receiver for ~5 seconds. Those settings will now be stored under Scene2.
post #3 of 7
Thank you for the reply but unfortunately that didn't work. It still goes to AUDIO1 twice.
I have been playing with this thing for a couple hours now. Is there a way to hard reset the whole system? I am at a stand still. I know it's minor but it's driving me crazy.
post #4 of 7
Is audio1 set up as the audio in for that connection ?HDMI. You'd have to change that in the set up menu.
post #5 of 7
I played with the menu quite a bit and couldn't find anything but I'll try and check the menu again when I get home from work and see if I can find a setting within the receiver. I think I understand what you are asking, I'll try and see what I can find again.
Update: My HDMI1: Audio In is checked with HDMI1. Not Audio1.
Edited by Meyer23 - 1/4/13 at 8:24pm
post #6 of 7
Hi Meyer23, possible receiver HDMI Control has been turned on or the tv HDMI Control is turned on.
post #7 of 7
I'm having the same problem as the original poster. I have HDMI Control turned on, because when I use Netflix on my SmartTv, I want the audio to play through ARC.
However, the Yamaha always sets the audio input as AV4 when I turn it on, when instead it should be using HDMI2.
Is there a way to use HDMI Control & ARC - and have automatically set it to HDMI2 for input? Or maybe there's a better way to configure this?
