Originally Posted by Bond 007
Seems kinda redundant except I guess it would be nice to have that option. Delay is distance. The distance is calculated by the length of time elapsed between when the signal is sent to the speaker and when it is received by the microphone. Time delay. In fact, the only thing that I kept from my ypao settings was distance. You can measure with a tape the distance from your seating position to each speaker and that will work. I know that is heresy and I will get comments. What do you think people did before computers and without spl meters? It is not perfect nor does it need to be. No offense but you don't have a $5000 system (neither do I but not too far from it) and you won't know the difference.
You can always spring for the right equipment and you will have it for next time. If you don't have any experience in setting up a system without a computer and a decent working knowledge of stereo electronics and what all the settings do then that would be your best bet.
Also you can't expect to just set it up by ear in an hr and say there you go I'm done. Set it up with known settings that are basic for any setup. Then just use it and as you listen to it. Over time you will notice things that don't quite sound right. Then you tweak it. Then you listen for a while and tweak it some more. You're not gonna do it in an hr like a computer. It might take a week until you get it where you think it sounds really good. Then you will probably end up tweaking it some more. I really don't mind it. I get some satisfaction out of noticing something and being able to diagnose it and make it sound better. But you have to know the ins and outs of how things work and why. Some of these people that just let the computer set it up and never look back I guarantee aren't getting the best out of their system. I ran ypao 3 times in a row and got 3 different results. How accurate can that be?
What model Yamaha do you have? I have the 671 and it has an excellent 7 band eq built in. Once you figure out how to use it to its full potential you can work wonders. Especially with a patched together system like yours. You can individually eq each speaker according to its potential and maximize its best sound characteristics or help compensate for its deficiencies. I mentioned that in the 671 thread and hardly anybody even knew that it had an eq because its all about YPAO this and Audyssey that. If I posted this in the Audyssey thread I would probably be banned from AVS.
Anyway, I've given my colleagues enough ammunition. Bring it on. I will not argue. I'm just a nut.
Very sound advise! (No pun intended)
I've never been a big advocate of auto calibration. It's never worked to my satisfaction. I've spend many hours tweaking my system, and continue to check my adjustments now and then.. Although it's not a 'state of the art system' it sounds like one. One night I was in my garage which is adjacent to my den and I had forgotten that I left my system and DVR on. A movie started playing which had a chase scene, and there was a crash. It sent me running into the room thinking that maybe one of the trees behind my house had fallen. If you want to get the most out of your system, auto calibration or no auto calibration, it takes work. Reaching out to forum members for input will help get you started, but there's a lot of trial and error before you will get the results that you want.Ian
