AVS › AVS Forum › Audio › Speakers › Marantz Amplifier only playing through one speaker unless volume turned up then it kicks in!
post #1 of 3
Hi Guys
Newbie and already need some advice I have a Marantz stero all seperates and the amplifier a Marantz PM4001 is only playing through one speaker unless volume turned up then it kicks in.
I have tried blowing it out with an air duster and the problem does seem to be coming from the volume control I have switched the speakers and it does exactly the same.
Help! Its driving me crazy
Thanks in advance
Dean
post #2 of 3
Originally Posted by Dean Jeffreys View Post
Hi Guys
Reconnect the speaker wires, current left channel to right channel, current right channel to left channel. That will tell you whether the problem is in the speakers, wires or the amp.
If the problem moves to the other channel, then the amp or the source are the problem. If it stays in the same channel then the wiring or the speaker is the problem.
post #3 of 3
Hey
I have done this already and its exactly the same any ideas?
  Back to Forum: Speakers
  • Marantz Amplifier only playing through one speaker unless volume turned up then it kicks in!
