AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › HDMI 4x4 matrix repair help
post #1 of 3
I have a monoprice 4x4 matrix that got the wrong power cable plugged into it and popped.
I quickly shut it off and waited awhile before I plugged the correct power supply into the unit.
All the lights light up solid blue but no switching our source selections work.
Any advice on what I can do or a repair shop that could fix it?
Edited by EpicVegas - 1/4/13 at 3:15pm
post #2 of 3
Any ideas?
I would hate to just through this unit in the trash...
post #3 of 3
Bet it'l cost far more to fix if you can find some one to try then a new one.
  Back to Forum: Home A/V Distribution
