Hi everyone,
I have just upgraded my Yamaha to receiver to a new onkyo 515. I have an Eltax powered sub which worked fine with my old Yamaha receiver. However I can not get my new one to detect it and use it. I believe it to be plugged into the correct input and the power is on as well as the volume is turned it.
When I run the auto set up (with the mic) it does not play any sound and then the pic of the on screen sub is removed.
I can go into the settings and manually add but no sound comes out sill. All of the bass is delivered through my main speakers.
I would appreciate anyone's help with this.
Adam
Adam
Once plugged in to the correct input, then ensure the sub is set to "ON" and not "AUTO" while running the Auto setup routine. With the sub powered on, remove the cable from the sub pre-out and rub your finger over it .... do you hear static from the sub? If no, either the sub or the cable is defective. If yes, unplug the AVR for about 10 minutes and try the Auto Setup again. If still no joy, do the microprocessor reset procedure listed at the beginning of the Troubleshooting section in the Owner's manual.
