AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PLEASE HELP!!! - Connector broke, need opinion on component
post #1 of 7
My HDMI came unplugged. I went to plug it in and somehow it got caught on the gold connectors and bent 3 of them to the point I can't unbend them and plug in the HDMI. I don't want to get a new console yet if the new ones are coming out in a year or so. Any rate, I was thinking of just switching to component connector (going and buying a component connector with the PS3 end). My PS3 is an original 20 GIG model, bought it about half a year after they launched.
If I go with the component, will I be loosing anything in quality/capabilities from the HDMI? The site says the component will still do 1080P. Trying to determine if I should just get the cable or pay to have it fixed so I can use HDMI again? I have a pretty good top of the line Plasma TV and don't want to loose any features/picture quality because we watch a LOT of Blu-ray movies on it.
I read that newer models will not display Blu-ray at 1080p through component but mine is pretty old so I assume I am safe?
Any advice would be greatly appreciated!!
post #2 of 7
Not really. You should do fine. As for getting it fixed, check with Sony and see what they say in replacing that part, or find a place that does the work, and can replace the female end on the circuit board.
post #3 of 7
I would stick to component, cheaper for a cable. Who knows how much that fix would cost you.
post #4 of 7
Thanks guys!!!!
post #5 of 7
post #6 of 7
I found the monoprice component cables to be kinda stiff. Check partsexpress for belkin a/v cables at buyout pricing. Only limitation is the 6ft length.
post #7 of 7
Originally Posted by TornadoTJ View Post
That is where I got it from, love monoprice.
  Back to Forum: PlayStation Area
