Hi All,
I am a newbie without any technical experience. So would like some advice from you. Here is the situation: I have a spare Def. Tech supercube II subwoofer cabinet, but no components for it. I would like to see if I can build a subwoofer using that by buying components. My options to build this out are:
1) Buy Def. Tech amplifiers (low/high), woofer and 2 passive radiators from an authorized source - likely to be more expensive than buying a new subwoofer
2) Buy any 8"woofer, passive radiators and amplifiers from a kit - is this even possible ? if so where can I get it ? Would it even work ? the only thing I know is that the subwoofer volume is a very critical factor
3) Just not worry about building it as I will never get the sonic characteristics right if I use a third party kit and buying components from Def Tech is likely to be more expensive than buying a whole new subwoofer.
Let me know what you think. Appreciate your help.
