This is a bit of an oddball comparison, but since I have owned all these projectors, I figured I would compare them... So let's get this started, this is just a quick and simple summary. I just used a simple numbering system as a comparison indicator, because it was easy to write up fast. I could throw a bunch of others in the roundup, but figured this is enough.
Sharpness:
JVC RS-45 = 9.0 video, 9.0 text (The benq only appears a tiny bit sharper in video, JVC seems smoother on text, it could go either way)
---Keep in mind the JVC partially depends on convergence, but most newer JVC's are very sharp
Benq w7000 = 9.2 video, 9.0 text (very very slight "over-edginess" to text due to Pixel fill and 1x SW seating distance, though Benq looks sharper than JVC on certain colors over others)
Mitsubishi hc4000 = 8.0 for text, 8.5 for movies and overall viewing
Viewsonic Pro8200 = 7.5 for text, 8.0 for movies and overall viewing
Black Levels (this may surprise some)
JVC RS-45 (of course this wasn't the surprise) = 9.5
Mitsubishi hc4000 = 7.3 Only Native
Benq w7000 = 6.5 / 7.5 with DI enabled (I changed this rating because on the Benq you can control brightness by using a DI as a fixed IRIS)
Viewsonic Pro8200 = 6.5 Only Native
Color after calibration (by what the meter tells us, overall accuracy)
Benq w7000 = 9.8 (after a second calibration, I now think the Benq has the best color I've ever seen on any projector)
Viewsonic Pro8200 = 9.5 (excellent color)
Mitsubishi hc4000 = 9.0 (great color, but not nearly as bright and harder to maintain brightness while calibrating)
JVC RS-45 = 7.0 (some gamut issues that you cannot calibrate out causing yellow cast in some scenes, colors do look richer in dark scenes than others)
Color before calibration (going by eye + considering meter readings before calibration a little)
Viewsonic Pro8200 = 8.0 (a bit cool before calibration, though depends on each unit, also a bit of a RED tint)
Mitsubishi hc4000 = 7.5 (good color, but some green and red tint across the board prior to calibration)
Benq w7000 = 7.5 (mainly gray-scale issues but also a couple gamut issues, most modes too cool or too greenish blue)
JVC RS-45 = 5.5 (some issues with gray-scale and gamut, too much green and yellow + gamma crush)
Cleanliness of Image (only noticed in certain sources, equal much of the time)
Mitsubishi hc4000 = 8.5
JVC RS-45 = 8.0
Benq w7000 = 7.5
Viewsonic Pro8200 = 7.0
Overall Brightness:
Viewsonic Pro8200 and Benq w7000 = 9.0
JVC RS-45 = 7.5
Mitsubishi hc4000 = 6.0
Fan Noise and other noise levels in ECO MODE:
JVC RS-45 = 9.0 (quietest)
Benq w7000 = 7.5
Overall Features:
JVC RS-45 = 9.0 (lens memory and 2.35 support, most flexible placement, motorized, grayscale and gamma but NO FULL CMS - the higher end JVC's do though)
Benq w7000 = 7.5 (a decent amount of lens shift, no 2.35 resize ability for 16:9 on 2.35 screen, FULL CMS)
Mitsubishi hc4000 = 7.0 (no LENS SHIFT, full CMS, 2.35 resize ability for 16:9 on 2.35 screens)
Viewsonic Pro8200 = 6.5 (no LENS SHIFT, full CMS but does lack some gamma calibration abilities, default gamma presets are usually fine though)
That is about it for now.
Edited by coderguy - 2/5/13 at 2:44pm
Sharpness:
JVC RS-45 = 8.0
Benq w7000 = 7.5
Overall Brightness:
JVC RS-45 = 7.5
Benq w7000 = 7.5
Overall Features:
