AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Enough power
Enough power
post #1 of 3
Hello,
I have a older Yamaha AX-596 100rms 145 max. I was wanting to replace my Athena AS F2s with Cerwin Vega CLS-215 my question is this amp enough power for these speakers or will i need to add an amp.If i need to add is there one that's not terribly expensive.
Edited by pbaker - 1/5/13 at 10:09am
post #2 of 3
According to this review the CV's are very easy to drive, so your Yamaha integrated amp should be fine.
http://www.theabsolutesound.com/articles/tested-cerwin-vega-cls-215-loudspeaker/
Give it a try and if you find you need more power then add an amp. I certainly wouldn't buy an amp first w/o testing the speakers with just your Yamaha.
post #3 of 3
thank you very much for your opinion,I appreciate it very much.
