AVS › AVS Forum › Audio › Speakers › Klipsch F1 vs Infinity Primus P363
post #1 of 3
Hi guys, Im looking to buy a pair of floor standing speakers for my room. I am currently looking at either the Klipsch F1 or Infinity Primus P363 as both are currently on special and can be had for about 250 (pair). So my question is, if you had the choice between these speakers, which would you choose? Thanks!
post #2 of 3
Have you heard horn/compression speaker before? Some love them, others do not...
I have heard the Infinity Primus p363 speaker and it is a good budget speaker! Alittle warm, but solid for the dollars!
post #3 of 3
I would choose the 363, because I prefer wide dispersion speakers with consistent off-axis response.
  Back to Forum: Speakers
