AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › CAN'T RECORD NETFLIX ANYMORE TO PANNY
post #1 of 83
Does anyone know if Netflix changed something to prevent recording shows ?? I used to be able to and other streaming channels still work.....I'm pretty sure it's not an hdpc issue as I'm only using composite cables and Like I said it used to work.......Any ideas ??.Thx...
post #2 of 83
Doe the recorder tell you anything? What exactly is the failure mechanism?
post #3 of 83
Less than a millisecond after I push the record button a warning pops up on the screen saying "Recording has stopped Copyrighted material cannot be copied"....WTF ??
post #4 of 83
Netflix has always used copy-protection on much of its streaming content. That has been required by the content providers. Up until now you may have been recording stuff that they didn't have to protect and so you were successful. They may have changed that policy on that content.
post #5 of 83
You're probably right as I noticed that I was able to record some programs before but now it seems that all are blocked......Didn't think they could do that without Hdcp and only through Hdmi......Can't get away with anything anymore........ mad.gif ...Even tyring to record the exact same movie as I did before doiesn't work now.....Guess they are on to us......
post #6 of 83
As you indicated, HDCP is the instrument of copy-protection for digital HDMI inter-connects. For analog connections they just use good old macro-vision. You can probably get a macro-vision filter like people do for recording copy-protected content from their cable boxes.
post #7 of 83
post #8 of 83
What do you recommend
Grex, MCM, Sima CT, Copiall, am I missing any?
post #9 of 83
That error message leaves no doubt that it is a form of copy protection. As you say, it isn't HDCP, but that is oly the most recent variant of CP. There have been a number of CP schemes out there, and you machine IS REQUIRED to respond to any/all of them if it finds one. That's why so many recorders have been flagged as prohibiting copying incorrectly, when they see "something" that looks like it even might be CP they shut down with a false positive. frown.gif
Which one of the above do I recommend? I have a SIMA, and it works, but it gets hot, so it isn't suited for leaving on all the time. It also tends to lighten the picture, which is bad. The one I recommend is not available any longer, the Video Filter. I have neverf used a Grex, but others here have.
post #10 of 83
Thx for all the comments.......Just found a unit on Monoprice that converts component to composite and one reviewer said it removes CP in the process but that's all that was mentioned so not sure if it's any good or even does the job since it's not mentioned anywhere else....
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=7114&seq=1&format=2
post #11 of 83
Yes that MP device will work for what you want, as long as the device your trying to record from has "component" outputs.
You can also find Lenkeng devices for around the same price that converts HDMI to S-video and also removes CP.
I've used both and can attest they remove CP in the process. Some of the more expensive HDMI to S-video converters(the ones that claim to be HDCP complaint) may shut down when they sense CP but not the cheaper ones.
post #12 of 83
Yeah, those look great !!! Any idea on price or where to buy ?? Checked their website but didn't see any North American dealers mentioned.....Thx again.....DT
post #13 of 83
Monoprice is a good place to purchase the Lenkeng(branded as MP) component to S-video converter and Amazon sells several different HDMI to S-video converters under $50.
post #14 of 83
Here's some info on Component and HDMI converter/filters... click in pics for sellers Monoprice.com
I'd be "leary" of the many sellers on Amazon since Lenkeng, the original mfgr, warns of counterfeiters, one of whom they say doesn't have any R&D capability.
post #15 of 83
That is great !!! Thx guys!! And the reviews aren't bad either....Checked on Amazon and seemed they were all out of stock and MP has always been trustworthy.......The HDMI > S video one sounds like it gives better PQ and I've got all three types of outputs on the BD player so for a few bucks more might just go with that one.......Thx again......DT
post #16 of 83
If your recording from BD I'd really suggest the HDMI model. Even if your BD player has component outputs apparently the spec for BD allows disc mfgs. to disable all outputs except HDMI. Don't know if they'll ever implement this but it could be a worry if relying on component. Besides AFAIK all BD players made after '11 were required to omit component outputs, only HDMI and maybe composite.
The HDMI to S-video converter I have is the 1st one in wajo's link, not a bad little device and well priced smile.gif
post #17 of 83
Just using the BD for Netflix and wanted to record it from there onto my Panny VHS/DVD burner combo......Like I said in the original post, I used to be able to record some programs but now it seems all are CP'd but yes I think I'll go with the Hdmi one.....
post #18 of 83
Also have Roku with Hdmi output but waaaayyyyy more programming than the BD player and would be nice to be able to plug that in to the burner/ recorderwhenevr I wanted to make a copy of something.....
post #19 of 83
post #20 of 83
Will all these units work for C.P. on Netflix or do they only unblock Tapes etc.???
post #21 of 83
If they're using Macrovision (and they most likely are on the analog stuff), then they'll work just fine.
post #22 of 83
The Roku LT and Roku HD have composite video (analog) output that would work with these filters just fine, and some stuff may not even have copy protection. The Roku 2 XD and XS have HDMI only, so that's probably the one you have. Given that no recorder has HDMI inputs (in the US), you'd need to both remove the HDCP and convert the signal.
For recording, I'd just buy another Roku LT for $50 and use that, and not mess with converting the HDMI signal.
post #23 of 83
Originally Posted by Tulpa View Post
The Roku LT and Roku HD have composite video (analog) output that would work with these filters just fine.......The Roku 2 XD and XS have HDMI only, so that's probably the one you have.
Not true. The Roku 2 XS DOES HAVE composite video output. It connects to a recorder using a 3.5mm>RWY RCA cable and works well with my Sima CT-2 filter. smile.gif
post #24 of 83
All 4 Roku models here show "480i (over composite video)" output under the See specs links (under pics)..
post #25 of 83
A couple of the earlier Roku models had Component video output but they dropped it in favor of composite video. mad.gif
post #26 of 83
Yep, I found this out last week myself. I'll have to pick-up a filter too. But HBOGO and EpixHD can both still be recorded off my Roku! eek.gif
post #27 of 83
My Roku has Hdmi and Composite outputs but it won't let me record anything from Netflix when hooked up to my panny vcr / dvd burner combo so......that's why I need a converter box that will take Hdmi in and output S video into the Panny and remove the Macro C.P. that is on Netflix..... Or I can output the Netflix from a Sony BD player in either Hdmi, Composite or component but the DVD recorder will only accept composite or S video so, if I'm converting from an Hdmi signal down to a composite S video signal would Hdcp even be a concern ?? If so I can always get a converter that goes from component down to S video but an earlier poster said I'd get better PQ if I went with the Hdmi route..........Your thoughts ??
post #28 of 83
Yes it only seems like Netflix is affected......I guess because it's the biggest and people pay for it.....found a couple reasonably priced filters at Monoprice and Tiger direct.....
post #29 of 83
@ diverted post #27. CP is a concern even with composite video,that's why you'll sometimes need a filter. I have used the HDMI output on my Roku 2 XS with a HDMI>Component video converter>Component>svideo converter, AND the composite video output with my Sima CT-2 filter and haven't noticed much if any diff. in video quality in my recordings.
Edited by greaser - 1/7/13 at 12:48pm
post #30 of 83
I ran in to CP one time when i rented a movie from Vudu and had to stop the movie long enough to connect my Sima filter,then restart the movie from the beginning. tongue.gif But it only happened once....none of the other movies i rented/recorded from Vudu had CP enabled. cool.gif .....so far rolleyes.gif
Edited by greaser - 1/7/13 at 1:10pm
  Back to Forum: DVD Recorders (Standard Def)
