Hi all,
I have been a long time forum observer and value the knowledge that is housed here. I'm piecing together a new entertainment center, 95% movies 5 % music.
I have a built-in entertainment center that has two cubby holes for speakers, the holes are 18Wx19Dx11T
I have an new ONKYO reciever, an old Phase technology center, sub and L and R fronts, Bose rear surrounds and axiom wall mounted speakers in a zone 2.
The L and R fronts have begun to crackle a little and the foam on the woofers has gotten gummy so i'm in the market for a new set of speakers.
After combing the forum for a a few days i narrowed it down to the Deftech 55's and Monitor Audio - Silver RX-1. but then i realized that i would be placing the speakers on there side:
A. is this a problem
B. Can you recommend the best horizontal oriented speakers that can fit in my cubbies
C. or best speakers period that will fit my space and work when placed on there side.
although not ideal, for cost reasons i am going to keep the phase logic sub and center. originally i was looking to spend between 4 and 500 dollars but heard the 55's and thought they where worth the money.
thanks
thanks
