AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Advice on Home Theatre Setup
post #1 of 5
Hi all,
I'm looking for a setup which will suit my requirements below. I'm not an audiophile and I'm not looking for a high grade setup, simply something that will improve (hopefully immensely) on my current LED speakers.
As you can see from my current setup (pictures), I hate visible cables. I'm looking for a setup which will give me the ability to have the least amount of cables and the need for me to have electricians in my house.
I have looked high and low at several different solutions and I have come to the conclusion that I need 2.1 setup. This would mean I can have an amplifier in the corner (next to powerpoint) and will only need to run speaker cable to mounted speakers (next to TV) and a HDMI cable from the TV to the amplifier.
I did look into soundbars with wireless subwoofers but there are more set backs to this approach. I would need to:
  • Install an additional powerpoint just for the soundbar (behind the TV)
  • Make sure that the soundbar power has a low profile power adapter (I could get a recess powerpoint or look for a flat profile third party power cable)
  • Still have to run HDMI cable from the TV to the soundbar or wireless subwoofer.
  • Still have to power the wireless subwoofer
My OCD and hate of cables does make this hard but I think I will need to have some drilling and wiring of cabling done but I'm hoping that I won't need to have an electrician in to wire speaker/HDMI cables - I could be wrong though.
Can anyone shed any light on a setup that would enhance my LED TV's speakers and meet all my requirements (see below)?
Budget:
  • Less then $500 $1000
Setup:
Use:
  • Stream TV / Movies from NAS to Apple TV (XBMC)
  • Airplay Music from iPad/iPhone using Spotfiy to Apple TV
  • Watch free to air TV 2 - 3 times a week
Pictures:
Edited by schone - 1/6/13 at 3:17pm
post #2 of 5
Originally Posted by schone View Post
Hi all,
Budget:
  • Less then $500
Setup:
Use:
Pictures:
AVR - obviously an entry level unit - any ca. 100 wpc 5.1 AVR from a major manufacturer such as Denon, Pioneer, Yamaha,
A pair of speakers such as Infinity Primus 163s = I think Amazon and some others have excellent deals on these fine-sounding speakers.
The first upgrade would be a good subwoofer such as the Polk Audio PSW 505 on sale from Egghead.
post #3 of 5
Funny, as soon as i saw the photos i get your ocd. nothing is out of place, no knicknacks, no mess.
Where is this? I see the room is open to the outside, certainly not the northeast.
I suggest a decent set of floor standing (non powered) speakers. You can run the wire behind the trim on the bottom to the avr.
Or, your tv must have a plug behind it, i doubt you hard wired it. so you can plug sound bar there.
post #4 of 5
Awesome thanks for the feedback! I will have a look around at those AVR's and also those speakers as they seem like a good buy.
I'm in Melbourne, Australia - the room is just an open plan kitchen/living/dining room.
I think the floorstands and AVR would work best as I'm worried about purchasing a soundbar which has an adapter pack and have no where to hide it and would need to have another powerpoint installed behind the TV.
post #5 of 5
Just wanted to add that I may need to increase my budget. So I could go to $1,000 if needed.
