Help?
Featured Stories
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How... - Page 47
AVS Top Picks
- cdnbum88
- Trader Feedback: +1
- offline
- 348 Posts. Joined 4/2009
- Select All Posts By This User
- AustinJerry
- Trader Feedback: 0
- online
- 3,325 Posts. Joined 1/2003
Comments:
- For frequency sweeps, you should measure 15Hz-20,000Hz. Your measurements stop at 1.15kHz.
- When using the camera icon for a screen capture, always include at least the Legend, which shows the smoothing you have used. What is the smoothing for the frequency sweeps?
- As a starting point, measure Left+Right+Sub(s), once with Audyssy off, and once with Audyssey on. 20-20,000Hz, of course. Use 1/6 smoothing. We can always drill down into the individual speakers if necessary.
- Using the same measurement as above, post a graph of just the low frequencies, 20-300Hz, Audysseoff and Audyssey on, no smoothing. (To see how the bass is doing).
- Then we can try and figure out what is wrong with the waterfalls, which don't look right.
- Forget the ETC graphs for now, we need to look at the basics first.
The room looks good, BTW. More detailed comments after we see the new graphs.
- AustinJerry
- online
- kbarnes701
- online
- 10,406 Posts. Joined 1/2008
Guys, I haven't chimed in to this thread in the last couple of days, but now IMHO this thread has come to a sad halt, members here are putting question after question that are left abandoned with no reply by the OP despite the promise to follow up each and every query, whatsoever, and also did not reach the goals set forth by the OP since the OP simply disappeared. With due respect to all human beings, my gut feelings are telling me that there is something wrong here, very wrong.
I dunno what the mods think about such a development or better said non-development of an otherwise great initiative, but IMHO this thread would be better if it were shut down.
Whaddaya think?
I think you have completely taken leave of your senses, Feri, if you don't mind my saying. I am finding the thread useful each and every day. If you are now finding it useless, just unsubscribe from it and your problem has been solved!
- kbarnes701
- online
Good reality check there, Jerry. And yes, I agree. Just watched Skyfall - amazing.
- kbarnes701
- online
Duh, finally figured it out how to post these.
Ok, I am sure I messed something up. Let me know your thougths.
Left No Audy
Right No Audy
Center No Audy
Left No Audy Waterfall
Right No Audy Waterfall
Center No Audy Waterfall
Left No Audy Impulse
Right No Audy Impulse
Center No Audy Impulse
I suggest you read and follow Jerry's Guide for the FR graphs. Towards the back he makes a list of all the essential tests you need to run, with the way to set the limits etc for each type of graph.
Brief comment (it is late here and I am tired, but I will comment more tomorrow) - the graphs show more or less what I'd expect from an entirely untreated room - a lot of ringing in the LF and a lot of reflections in the mid and HF. Can we see your Audyssey ON graphs as well so we can see what Audyssey is doing to try to correct the problems?
Your FR graph stops at just over 1Khz - we need to see all the way to 20kHz. Are you sure the subs are off for the L, R and C graphs?
Can you set the waterfalls to 450 msec too please and not 600? All this is in the Guide BTW.
- AustinJerry
- online
I'm actually re-thinking what the "essential tests" ought to be, and will post my ideas here sometime this weekend. My thinking is that there should be an initial "profile", which would include a couple of basic measurements to get a feel for whether the listening environment is "pretty good", or in serious need of attention. Then there would be a set of additional graphs that drill down into various aspects of the room that might need attention. Seeing a couple of participants post a long list of measurements that don't include the vital ones is a lot of wasted time and effort.
The profile could also include pictures, as Feri suggested, as well as a room diagram, and perhaps a basic speaker layout (e.g. 7.1 with two subs). More thoughts later--I need to enjoy my system for a change. Watched The Perks of Being a Wallflower yesterday--cute movie, no pyrotechnics.
- cdnbum88
- offline
I am sorry, I picked the first three 1.1, 1.2 and 1.3 in my dropdown and was not sure since they are not labeled L/R/C or anything if the sub was engaged as I did not turn it off. So if those first three options in the dropdown include then subs then Keith I guess they are included.
Jerry, I don't have a schematic of my room. I have the Def Tech Mythos ST's L/R and the Mythos 10 center and the Gem XLs for surrounds. I have a Seaton Sub HP. Marantz AV7005 with Emotiva XPA-5 amp along with an Oppo 93 and AS-EQ1. The sub is along the right side wall even with the couch back side and the other speakers I think you can see otherwise.
I will try to take another set of measurements this week, but heading to Asia next weekend for two weeks and not sure if the mad rush before that trip will let me, but if so will post it up.
Again, thank Jerry for the great guide and all others for your feedback. I certainly hope that the Audyssey on graphs will tame their look since overall when I added the AS-EQ1 to the mix the sound is so much better in a WAF room.
- AustinJerry
- online
I had an AS-EQ1. It is a great product. The most important measurement, when you get to it, is the left+righ+sub, Audyssey off and Audyssey on. If you output the REW signal to the main speakers, the sub will be measured as well. When I say Audyssey off, I mean the AS-EQ1 off as well.
No hurry on the measurements-we will still be here.
- kbarnes701
- online
Good idea Jerry. But may I suggest you also keep the current list. I found that really, really useful as a check list so that I knew I wasn't missing an important measurement that I would then need to go back and do later, maybe setting it all up again.
BTW, while I remember, the list I refer to also includes the mode the AVR should be in - stereo being the most used, with advice to set to PLII Cinema for testing the centre channel. Those of us with multichannel HDMI do not need to do this and the mode I use is straight Multichannel on my Onkyo (no DSPs engaged of course - this lights up the indicators for all speakers that can be tested - FR, FL, C, SL, SR, Subs in my case - and simply selecting the correct channel in REW plays the tone through the correct speaker, including the surrounds if required. For the tests on the satellite speakers alone, the subs are of course turned off physically at their power switch. I wonder if that needs to be included in the Guide in the section with the list of tests?
- kbarnes701
- online
Thanks for the feedback. I did try to follow the guide as best that I can. With axis and smoothing and what not and what tests to run, but as you can see I must have not managed to be consistent across all the measurements.
Yes, the sweeps show that the subs are included - I doubt if your FR, C and FL have that amount of extension. Once you have set all the right things for limits etc in REW, as per Jerry's guide, they are 'sticky' so you only need to get this right one time and it will stay like that unless you need to change it for some reason. The sub would be engaged if you are using Stereo mode as suggested in the Guide - you need to physically power it off with its switch for the tests that involve satellite channels only. In REW, the channels are:
1 - FL
2 - FR
3 - C
4 - Sub(s)
5 - SL
6- SR
and presumably (I don't use rear surrounds)
7 - RSL
8 - RSR
It is complicated at first but once you have used it a few times it becomes very intuitive. If you run the full set of 18 test on p68 of the Guide then you will have all the essentials you need for later analysis. This will save you having to keep setting up for measuring over and over because you later realise you didn't do, for example Centre + Sub(s).
- kbarnes701
- online
- RickD1225
- offline
- 435 Posts. Joined 9/2009
I have been sitting on the fence on whether to get a USB mic and get into REW again. I do have a XLR mic from my SMS-1 setup, but it does not have a separate calibration file. I think there is a XLR to USB connector, but I don't know if it would provide the power or not. I will probably just order the UMM-6 even though it is almost $100. Heck that doesn't amount to much since if I get into REW I am going to spend much more on room treatments, etc to make the improvements it will suggest.
- RickD1225
- offline
- AV Science Sales 5
- online
- 3,345 Posts. Joined 9/2011
Next problem, I can only get Java to work even though I am using HDMI. If i do not use Java the mic does not show up as a device choice. Lap top is an Acer. Any suggestions?
- amirm
- offline
- 16,011 Posts. Joined 1/2002
I am using HDMI connection, but am having the following problems. I can get audio, but can not get video to work. My problem has to do with my remote located equipment. I have a 20' HDMI 22ga running from HT to mechanical room below. From the equipment to the projector I have a 25' HDMI 22ga cable.
So here are standard things I try. Set the desktop temporarily to the lowest resolution that is in ATSC spec, i.e. 480p (720x480) or 1080i (not 1080p). See if that works. If it doesn't, then try setting the PC such that *only* the external display is live. That is, don't use "duplicate." These two techniques usually get me a picture. The reason they help is that the former lowers the speed of the signals over HDMI which is very helpful on long cables. The latter works because you don't wind up with non-standard resolutions driving non-PC equipment. Since you are just doing audio testing anyway, it doesn't matter what the video looks like.
. If not, simply use Java. The purpose is to get sound from the mic to the laptop. It matters not what the absolute levels are which this whole USB thing was supposed to remedy.- AustinJerry
- online
Mike, getting the desktop to display on your monitor is not necessary for REW. In fact, it can be distracting. Long HDMI runs can cause all sorts of problems, but it is out of scope for this thread to trouble-shoot them. I would substitute a short cable to see if the problem goes away.
Regarding the USB mic, I just tested it out again on my laptop, so let's walk through it. When you initially plugged in the USB mic, you should have received a message "loading device drivers", and then "device driver load successful". In Windows Audio, you should see the USB mic, and it should be selected as the default input device, with level set to 100%. In Windows Audio, you should also see the HDMI interface as the default output device.
Now, when you launch REW, select Java as the interface. You should see the HDMI interface as an option in the drop-down for Output Device. And you should see the USB mic as an option in the drop-down for Input Device. From that point on (assuming you got this far), you can use the Java interface instead of the ASIO interface. You just won't be able to selectively output to different audio channels. You get L+R in Stereo mode, and Center in PLII Cinema mode. Nothing wrong with that.
Where is your issue?
- AustinJerry
- online
One more thought: if you are using the front-panel HDMI jack on the AVR, did you configure that jack as HDMI in the AVR's Input Configuration menu?
- online
I posted earlier from my iphone. I was just coming back here to post that it works using a short HDMI cable, but then I can't use a long cable for the USB mic. Yes I can get REW to work, I am just trying to get it to work the way I want. Right now I have to walk about 80 feet and two flights of stairs to disconnect and connect the speaker that I want to test. Remember my equipment is located one floor and in a mechanical room. That is how I did REW before I bought the USB mic and defeats part of the reason I went with the USB mic over my existing calibrated XLR mic.
I know others also have their equipment remote located and thought I might get a response from others that have had this problem.
- online
I have access to the back of my equipment and I was using HDMI input number 4 and it is configured. REW works for me, just trying to get it to work easier.
- AustinJerry
- online
- online
Mike, maybe post some screen shots of your Windows config, ASIO setup and REW? this might help others with HDMI spot an issue. I'm only working with the RCA setup currently, but I've got an Asus laptop with HDMI coming on Tues that I'm setting up for a friend. I want to try and get REW working on it so I may have more insight then. Sorry, doesn't really help you now!
Not a configuration problem, since it works fine if I take the lap top to the mechanical area and connect up to the AVR there with a short HDMI cable. The equipment that I am using does not like the 20' 22ga HDMI cable feeding the signal to the AVR. Trying to decide if there is something better out there to use, like one of the newer HDMI cables or a CAT5/6 system. I would not just be doing this for REW. I would use this connection for gaming. You could carry an Xbox or PS3 into the HT room and plug it in.
- online
Thanks Joe. My set up for REW consists of 20' 22ga HDMI fro lap top to AVR and 25' 22ga HDMI from AVR to projector.
^^^^Just to confirm, when you said "it worked with a short cable" was that just with a short cable between the laptop and AVR? Did you mean that you got video working with this setup (i.e. projector was outputting laptop video to your screen)? Also, you said REW was working with your setup but based on your initial problem post, I'm assuming you meant REW works but only with Java? Just trying to confirm if you still have multiple problems (i.e. video output and multi-ch HDMI setup) or just the video output?
- Selden Ball
- offline
- 4,363 Posts. Joined 1/2001
I just thought I'd point out a difference between what jkasanic wrote and what you wrote about the cables. He suggested Monoprice Redmere cables. Redmere cables have active electronics built into them to optimally enhance the quality of the HDMI signal for that specific length of cable. 22 gauge High Speed Monoprice cables do not have that electronics, and you can't simply add Redmere cables to the ends of what you currently have.
In other words, he's suggesting that you'll need to pull new cables
Or, of course, get separate, in-line HDMI equalizers.
- Srgtfury
- offline
- 611 Posts. Joined 7/1999
- Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
AVS Top Picks
Recent Discussions
- › Houston, TX - Comcast / DBS 16 seconds ago
- › Sony VPL-vw1000 28 seconds ago
- › 2013 Formula 1 in HD 31 seconds ago
- › Projector recommendations for smallish apartment loft 1 minute ago
- › mini split cost? - ripoff check 1 minute ago
- › Biamping help 2 minutes ago
- › What are your most recent Hi-Res purchases? 2 minutes ago
- › plasma....it's just not that good. I'm not trolling! 4 minutes ago
- › SEOS 12/ DNA360 / TD12M Mains and Inwall Center Build 4 minutes ago
- › Can anyone recommend an appropriate speaker upgrade for my system? 5 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
