AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How... - Page 54
post #1591 of 3722
Hey guys,
After all this time, I got busy, and installed and set up my UMM-6 with the appropriate 90 degree cal file. The biggest obstacle was getting my laptop to stay on the Geoforce Nvidia HDMI-equipped card, rather than default to the mobile display and give me dead eight channel HDMI audio and mic. I tried Keith's 'incantation', and it didn't work until I picked the Geoforce with extended desktop on both laptop and my VT50 display. Argh.,...,
Anyway, after running the Ratshack SPL to get 80 db, I came up with a noise floor in the mid-50s and maximum sensitivity of exactly 120 db. Should this be a concern, at the extreme of the 'normal' range?
Also, how many measurements are you guys taking to get a publishable average? Do you recommend concentrating on MLP or the Audyssey basic three to eight, if my focus is the three seats in the MLP?
I only had time earlier to run one for the subs with no Audyssey, output down 10 db for the sub LFE, and with no smoothing, there's a needle sharp 30 db null at 60 and approximately 90 Hz eek.gif. I hope it goes away when I do more measurements and bring in my Mythos ST (currently at 80 Hz, but I'll be curious to see how they look at 60 as well) for full range at 1/6 or 1/12, with Audyssey engaged and DEQ off. And I'm only on battery power....with OM and L/R+sub plots post-Audyssey at 1/12, those dips were much milder (not even -5 db).
Finally, is it good form to capture all speaker configurations of interest (e.g. L/R+subs) at a position and move on to the next position (then averaging each configuration by selectively picking the measurements), or getting all OCD and doing all X measurements by configuration, averaging, then moving on to the next configuration? I'd think the former, but as a REW neophyte, it doesn't hurt to check before I create 48 temporary files at one sitting LOL....biggrin.gif
Edited by sdrucker - 2/23/13 at 10:42pm
post #1592 of 3722
Took some measurements with Audyssey engaged. Subs only, no smoothing, dynamic EQ engaged and no boost added.
Left speaker and subs, Audyssey and dynamic EQ. 1/6 smoothing.
Mike - could we see those again but this time without Dynamic EQ?  Just for comparison purposes both with your own graphs and those of others (normally posted without DEQ in place).
post #1593 of 3722
Originally Posted by sdrucker View Post
Hey guys,
You  did do the incantation in Latin I assume?  This is one of the difficulties with using Windows I think - everyone has a different configuration of hardware and nobody can say for sure that what works for them will work for someone else - your Geoforce Nvidia being a case in point. Good sleuthing anyway...
We are all seeing a noise floor of about 50dB with the UMM-6, instead of the actual noise floor of more like 40dB. I think we are all ignoring it and carrying on. I raised the SPL calibrated level to 85dB instead of 80dB to see if it made any difference to my graphs, but it didn't seem to. It just made the test tones a lot louder. During the discussion with Jason (remember Jason?) where he was advocating testing at 100dB, didn't someone say that modern measuring software is designed to work with realistic levels of background noise anyway?  For example, I bet you never get Audyssey giving you an ambient noise warning and raising the chirp levels do you?
I only care about the MLP so I have only being taking one measurement at the MLP for each speaker or speaker combination. I may try using three or four mic positions for each measurement at some stage to see if I get a much of a difference.
Don't forget Bill Fitzmaurice's 'Graphitis Nervosa' which basically, once infected, means you spend inordinately large amounts of time trying to correct or compensate for things that you can see clearly on graphs but cannot hear at all with your ears.  It will be interesting to see your graphs. BTW, I get some differences between my OM/Omnimic and my UMM-6/REW too. It seems the UMM-6/REW combination has more 'resolution' sometimes - maybe it's the calibrated mic. Or maybe REW is doing things a little differently. FWIW, I have more confidence in REW.
Does it make any difference?  One of the great things about REW IMO is that you can capture the measurement results and THEN do anything you like with them afterwards. But I haven’t used more than one mic position yet, so I haven't needed to do any averaging.
post #1594 of 3722
Hey guys,
To add a bit to Keith's response:
A noise floor of ~50dB is as good as it gets with this mic.  At this time, it is still unclear whether the higher noise floor (when compared with the balanced EMM-6, for example, which measures a noise floor of ~40dB) has any meaningfull impact on our measurements.  I would guess that the waterfall might be impacted, but I am not sure.
As far as a measurement average is concerned, IMO the average has limited value.  For example, when you are sitting in the MPL, what does an average response graph tell you about the sound you are hearing--nothing.  I think that since we believe Audyssey is somehow averaging the 8 measurement positions to produce the smoothest response over the listening area, perhaps an 8-position average using REW would give us some insight into what Audyssey is doing.  Perhaps this is true, but so what?  If you do take a number of REW measurements at points outside of the MLP, it might reveal one or more points that exhibit an undesirable response anomaly.  Such an anomaly, if at one of the 8 Audyssey measurement points, could be skewing the Audyssey calibration.  Knowing this, you could either try to correct the anomaly, or "game" Audyssey by avoiding the anomaly during your calibration.
So, don't bother publishing the average.  IMO, here are the six most meaningful measurements to publish in your first go-around (all taken from the MLP, with Audyssey on and DEQ off):
- Left+Right+Subs, 15-20,000Hz, 1/6 smoothing.
- Center+Subs, 15-20,000Hz, 1/6 smoothing
- Bass response 15-300Hz, no smoothing (using one of the two measurements above)
- Waterfall 20-300Hz, (also using one of the first two measurements)
- Impulse ETC graphs for the Left and Right speakers, measured individually, 20-20,000Hz, with subs off.
The first three measurements reflect what you are actually hearing at the MLP.  For example, you never hear just the bass, or just the left speaker.  If this first set of graphs indicates issues that you want to understand and resolve, that is the time to start drilling down into the detailed measurements, isolating single speakers, etc.  Don't produce 48 measurements the first time around!
Of course, this is just my opinion, and I would enjoy hearing other viewpoints.
post #1595 of 3722
Hey guys,
FWIW, I am doing it the way you recommended and it is fairly quick and painless and has produced useful, meaningful results for me, leading, so far, to the application of a few additional treatments (arriving next week).
Someone in the 818 thread just asked what the difference was between Dynamic EQ and THX Loudness Plus, so when i measure next week I will do a comparison of the two and see what is going on. I find them to be virtually identical when listening, so it will be interesting to see if they are very different in the way the operate. They shouldn't be really as they are designed to do the same job - to compensate for human hearing as loudness varies, dynamically. I'll post the graphs here too if anyone is interested.
post #1596 of 3722
Hi all, ran first test this morning following the guide and my graph don't look the same as the guide on page 50-52 ... it show a down slope at 40 Hz confused.gif.
post #1597 of 3722
Which speakers are you testing there?  Can you post the graph again with the Legend showing so we can see?
A graph that shows a reasonably flat response from 20Hz to 20kHz will be one showing the response of, say, the RF + RL + Subs or C + Subs.
Your graphs don't seem to have the sub working at all. They appear to be RF, LF and C only.
Also, the agreed standard for posting graphs of the full spectrum is 15Hz to 20kHz, 1/6th smoothing. Can you readjust yours please?
EDIT: here's mine for RF + LF + C - not all that different to yours, broadly speaking:
And here is one showing C only + Subs:
Edited by kbarnes701 - 2/24/13 at 9:52am
post #1598 of 3722
Hi Keith, I'm having problem saving the graph w/legend as well and posting it here. I must be missing a few steps since I didn't have this problem when playing with the Audyssey mic last month.
You're correct, its showing only left, center and right only w/o the sub running.
The graph is set to 15Hz to 20kHz and 1/16 smoothing. I will try to capture the graph again to show the legend.
post #1599 of 3722
ATM the graph is set 6Hz to 30kHz. It isn’t important except it makes comparisons a little more difficult 'at a glance', hence Jerry's 'standards'.
As the graph is only showing RF + LF + C with no subs, then it is as expected. If you follow Jerry's Guide, there is a chart showing the standard basic measurements to take - follow that and you will have a full set that you can then manipulate in various ways. Remember that when you take RF, LF and C only, you need to physically switch off the subwoofer(s). To measure subwoofer only select Ch4 in REW Preferences. To measure RF + LF + Subs, select Chs 1 and 2 in REW Preferences. To Measure C + Subs, select Ch 3 only.
To save the Legend when you make a capture of a graph, tick the Legend Box as here:
Any text you type into the box below the tick boxes will appear at the top of your graph.
post #1600 of 3722
Ah, so my graph don't look like the guide (page 50-52) is because the sub is off.
Some how I forgot how to save the graph w/legend, any help there?
post #1601 of 3722
Correct.
See above.
post #1602 of 3722
Got it, thanks Keith.
post #1603 of 3722
BTW, not at home so I can't mess with my equipment but I just thought I'd comment on a post that caught my attention a little while back.
Someone posted a link to the Alesis Miclink, an XLR to USB interface and wondered about using it for folks who already have an EMM-6 for eg. to turn an EMM-6 into a USB mic.
A) IIRC, the Miclink does NOT provide phantom power, i.e. you'd need a separate source to power the mic.
B) The audio quality of the Miclink isn't the best. If the differences are audible in recordings, what do you think the measurement results will be? Right.
There are other XLR to USB interfaces that DO provide phantom power though. The Blue Icicle is one (and one of the cheaper ones that's a viable option at ~$50+). The Shure X2U has a better interface and lower pre-amp noise but it's about $100-$125. There's also the CEntrance MicPort Pro, which apparently has one of the lowest self-noise levels but costs about $150. These devices can plug directly into an XLR mic and the USB cable then goes into your PC. I'll admit that I'm curious as to whether the EMM-6 + MP Pro would produce a lower noise floor, but it's a purely academic consideration, as to whether the 10db noise floor difference is worth the extra $50 over the UMM-6 for those who already have an EMM-6 (=~$250 vs $100 for the EMM-6 combo vs UMM-6)..
Max
post #1604 of 3722
To perform this measurement, go into REW Preferences set Output as "Audio HDM OutI 1" , Timing Reference Output as "Audio HDMI Out 2" and leave the Subwoofer turned "on"?.
post #1605 of 3722
Yes. The sub will always play, due to bass management, unless you specifically turn it off with its power button.
post #1606 of 3722
The problem is, in my room, it is impossible to have a reflective surface at those distances, given that the MLP (and thus the mic) is approx 9.5 feet from the centre speaker.
direct signal T=0 will not give accurate total time of flight paths. this is why we use hardware loopback. however, it is not "impossible" to have a reflective surface at those distances.
why would one assume the only sources of indirect energy are from large walls/boundaries?
post #1607 of 3722
Step 5: REW Microphone Calibration
Note: With certain USB microphones, calibration is not necessary. Currently, only the UMIK-1 is recognized by the REW beta software as having a sensitivity parameter that allows REW to calibrate the microphone automatically. All other microphones must be configured manually using this procedure.
Any idea, will REW ever have a sensitivity parameter that allows REW to calibrate the Spectrum UMM-6 microphone automatically? I want get the UMM-6....
post #1608 of 3722
Then get it - manual SPL calibration of the UMM-6 takes all of 5 seconds.... and loading the mic's cal file into REW takes even less time.
post #1609 of 3722
post #1610 of 3722
Questions are good - they lead to answers!
post #1611 of 3722
Does anyone have the "cheat sheet" for HDMI settings for the various tests (e.g. R+Sub = input channel X and output channel Y etc)?  I know it was posted somewhere in here but I can't seem to locate it.  I suggest this be included in the guide as a reference if possible.
post #1612 of 3722
Guess it's time for me to move up from my RS meter. Suggestions for the EMM-6 (since I still have the usb pre)?
Michael
post #1613 of 3722
Thank you so much for this guide! I followed it step-by-step with a Windows 7 laptop (hdmi and it recognizes 8 channels) and UMIK-1 mic and it could not have gone easier. I still have a lot to learn, but here is what I am getting with my 4 DIY subs in my room after running Audyssey XT:
No smoothing, all speakers set to small, mains crossed over at 80hz. My amp (iNuke3K DSP) has lots of EQ/filtering options, but I am pretty happy with what I am seeing (assuming I am reading this right).
Any thoughts?
post #1614 of 3722
These are the channel designations in REW. You can use any combination of any two at one time. Sub(s) will always be active unless physically switched off.
Channels in REW:
1.     = FL
2.     = FR
3.     = C
4.     = Sub(s)
5.     = SL
6.     = SR
7.     = RSL
8.     = RSR
post #1615 of 3722
Any thoughts?
Can you remake the graph following the guidelines in the Guide?  That is, we need to see 5dB steps on the left not 20dB, 15-300Hz unsmoothed for bass frequencies and 15Hz - 2-kHz 1/6 smoothed for full range. Thanks. You current graph is hiding too much detail in that 20dB spread.
Spoiler: you may be less happy with what you are seeing when you apply 5dB increments ;)
post #1616 of 3722
Thanks Keith...I'm really struggling getting HDMI to work.  I think this ASUS laptop that I just got also has a Realtek ASIO driver and I can't seem to get REW to recognize the prepro or mic (it worked yesterday when I did the ASIO4ALL install) even though both are set as default in the sound control panel.  I guess just to make things even more complicated, it is a Windows 8 machine.  HST, once you install the patch to get your start menu back, it feels a lot like Windows 7 under the hood.
post #1617 of 3722
Spoiler: you may be less happy with what you are seeing when you apply 5dB increments wink.gif
Will do, thanks. No worries if there are things to fix, I expected there would be. I have a large open room, so it could be difficult to tame.
Thanks again, you guys are doing a great job. I would still be trying to get all this to work without the guides and help.
post #1618 of 3722
Off topic question. I'm curious to know if anyone knows how our brain handles sound. I know it kind of takes bits & pieces & creates the noise we hear. I'm trying to apply this to the smoothing that we use. In other words, is 1/6 or 1/3 smoothing comparable to how the human brain will interpret sound?
post #1619 of 3722
It really depends on a bunch of things (complexity of sound, SPL, temporal characteristics, spectral balance, etc). For pure tones at moderate volumes, we can distinguish bandwidths of 2-3 Hz. For higher frequencies and more complex sounds, the bandwidth can be anywhere from a few Hz to an octave. This range in perceptible "smoothing" is what makes it so hard to develop good lossy audio algorithms for a hifi audience.
post #1620 of 3722
I am using an Asus with the ASIO4ALL driver too and it works here, but I am using W7 not 8. If it worked once for you then it can work again I guess. I found I could only get it to work 100% reliably if I followed a strict procedure for cabling up and switching on, which I posted a fe posts back.
