AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How... - Page 56
post #1651 of 2883
Originally Posted by kbarnes701 View Post
Whatever John does, I do hope that most of us, in this thread at least, will be making a donation.
I was impressed enough with the software (even though I couldn't use it much) that I made a donation my first time around. Now, with a EMM-6 on its way, I think there should be a way of donating to THIS project.
Michael
post #1652 of 2883
Originally Posted by AV_mike View Post
Hi JohnPM,
Here is some Windows 7 data, as requested. Can't help with Win 8, may be able to do Win XP later.
Data as follows:-
First column = Windows 7 Level control setting within Control Panel
Second column = Reading taken from REW SPL meter (just below A/C/Z button)
Third column = REW levels did not change for every Windows 7 control adjustment, so this column lists the values at which a change occurred, as the values were decreased. This is why some REW values remain unchanged in the first two columns.
100 -18.7 99
95 -20.1 87
90 -20.0 77
85 -21.4 67
80 -21.4 58
75 -22.7 51
70 -22.7 44
65 -24.1 38
60 -24.1 33
55 -25.5 28
50 -28.1 24
45 -28.1 20
40 -29.4 16
35 -30.7 13
30 -32.0 11
25 -33.4 8
20 -36.1 6
15 -37.5 4
10 -41.2 2
5 -43.9 1
0 -48.0
Independent SPL meter read 99.2dB
Win7 Level slider range was 0.0dB to +20.0dB
Regards, Mike.
Edit, tried to respace the data, but extra spaces keep disappearing, sorry.
Nice job, AV_Mike.
post #1653 of 2883
Guys,
Thanks for starting this thread. It's extremely helpful!
Quick note for anyone planning to use UMM-6 along with the "On Stage Stands MS7701 Tripod Boom Microphone Stand ".
The threads in the clip provided with the mic are different from what the stand supports, so you can't attach the mic directly to the stand. I just ordered a universal mic clip (On Stage MY200) which should hopefully work.
post #1654 of 2883
Originally Posted by logicators View Post
Guys,
Both sets of threads are different?
post #1655 of 2883
Yes. The threads in the mic clip are smaller.
post #1656 of 2883
Also, what do you mean by "both sets of threads"?
Only one side of the boom have threads on my stand. The other side have some sort of a plastic handle.
post #1657 of 2883
Take a good hard look at the microphone clip. That threaded bit is an adapter screwed to the main body. You get two thread sizes from which to pick.
post #1658 of 2883
post #1659 of 2883
Aha. Found it.
Thanks a lot!
post #1660 of 2883
Originally Posted by JohnPM View Post
Hello all,
To add support for UMM-6 in REW I need to know how the Windows input volume setting affects the levels coming from the mic, anyone fancy helping with that? It involves:
- Setting up the mic pointing at and very close to (within a few inches) the midrange unit on a speaker, needs to be on a stand or supported so that it doesn't move during the test
- Opening the Windows Levels control for the mic (e.g. on Win 7/8 Control Panel -> Manage Audio Devices -> Recording Tab -> select the UMM-6 -> properties -> Levels tab)
- Opening the REW signal generator and start it generating a 1kHz sine wave
- Adjusting the AVR and/or REW's signal generator level so that the tone is at a decent level, shouldn't be loud in the room (since the mic is very close to the speaker) but a good level will give a more accurate result for the next part
- Opening the REW SPL meter
- Recording the REW SPL meter dB FS readings from the small figure above the horizontal bar, just below the A/C/Z weighting selector buttons, for as many Windows Level settings as you have the patience to write down, but as a minimum the levels at 100, 90, 80, 70, 60, 50, 40, 30, 20, 10 and 0.
- The final step is to place an SPL meter exactly where the mic was and record what SPL reading it shows with the sine wave playing from REW at the level used when noting the figures
Ideally I need that info from Windows XP, Windows 7 and Windows 8 as they differ in how they handle level settings. An extra handy bit of info would be the Windows volume control dB readings with the slider at each end of the scale, which can be obtained (on Win 8 at least, I'm guessing Win7 also) by right clicking the volume slider and selecting the decibels option.
Could also do with getting the same info for an Omnimic used on Win 8 (I already have Win 7 data for that).
Hi JohnPM,
Data as follows:-
100 -18.7 99
95 -20.1 87
90 -20.0 77
85 -21.4 67
80 -21.4 58
75 -22.7 51
70 -22.7 44
65 -24.1 38
60 -24.1 33
55 -25.5 28
50 -28.1 24
45 -28.1 20
40 -29.4 16
35 -30.7 13
30 -32.0 11
25 -33.4 8
20 -36.1 6
15 -37.5 4
10 -41.2 2
5 -43.9 1
0 -48.0
Regards, Mike.
Mike, something seems to be wrong with your data.  Looking at John's instructions, he says to place the SPL in the same spot, vary the mic level, and read the SPL level.  Your SPL measurements go all the way down to zero.  I know for a fact that the SPL meter always measures at least the noise floor of your listening room which, if like a typical rooom, is around 40dB.  So how can you be seeing a SPL reading of zero?
Perhaps I am not interpreting John's instructions correctly.
post #1661 of 2883
Hi AJ,
The actual sound level during the test remains constant - but the Windows Control Panel level slider is reduced from 100% to 0%, and the REW values recorded. Also, the REW value is not the SPL reading, I think it is the headroom value - as John explained it's the small digits under the A/C/Z selection button.
Hope I've done it right - might have to wait for confirmation from JohnPM.
Regards, Mike.
post #1662 of 2883
I'm still not understanding, Mike.  Are you saying you are connecting the SPL to REW using the laptop's microphone-in jack?  If yes, did you calibrate the SPL?  Did you use the SPL calibration file as well?
Unfortunately, John's instructions were not very clear.
post #1663 of 2883
Guys,
Same stand I own.
So no other adapter is needed? I plan on ordering the UMM-6 soon.
post #1664 of 2883
I do not know that for certain, although I have a strong suspicion that this is the case. Unless and until I'm shown that I'm wrong, I'm going to assume that the mic clip uses a standard thread common to microphone booms, and that the adapter just makes it easy to use the mini-tripod or indeed any photographic tripod.
COULD there be a third thread size that gets mixed in to this jumble? Sure, of course. I just wouldn't purchase anything until I knew for certain.
post #1665 of 2883
I can confirm that no separate adapter is needed. I have cancelled my universal adapter order.
As JD in NJ have mentioned the mic clip actually supports two thread sizes and when I removed the outer adapter from the mic clip (which is not very obvious) it did fit nicely on the mic boom thread.
post #1666 of 2883
Nice! Thanks guys.
post #1667 of 2883
Perfect, thanks Mike.
post #1668 of 2883
I have been using REW now for a few weeks and I am loving it. I wanted to make a donation to you as some way of saying 'thank you'. I went to the HTS website but when I go to make a donation, it seems as if the donation is going to HTS rather than to you. Is there something I am missing, or is that the way to do it?
Yes, that's the way to do it (why do I suddenly sound like Punch?).
post #1669 of 2883
When I do the initial test on page 49 with just the Left Speaker, I get two readings on the graph instead of one. The curve at the top of the graph looks similar to the example on page 50 though much more jagged, but the one at the bottom is different. It shows dashes leading straight up, and then falling like steps. I'll post later.
post #1670 of 2883
That sounds like the spl & phase graph . If you look right above the graph in REW there is a button that says ALL SPL. Click on that and it should change the graph to look like the others on here. I hope this helps.
post #1671 of 2883
Thanks. I'll try it when I get home.
Edit: I'm learning I can only do these measurements in the early afternoon when no one's home.
Edited by Pres2play - 2/27/13 at 12:27am
post #1672 of 2883
Can someone explain what the Meter is showing? Which window shows the actual noise floor? Why is the SPL window on top moving without any measurements being taken?
Edited by Pres2play - 2/27/13 at 1:05am
post #1673 of 2883
Thanks John :)  Then that is how I shall do it this very day. Thanks you for all your hard work on REW. It is staggeringly good.
post #1674 of 2883
The big window shows the noise floor, or indeed anything that the mic can pick up. The figures in the big window will always show something, if the mic is plugged in, because there is always some background noise present. It fluctuates a little because the noise it is detecting also fluctuates a little.
post #1675 of 2883
Are you sure that's not some headroom number in the big window? I thought the room was quiet when I took that reading. 50 dBs looks good to me now.
post #1676 of 2883
Yes I'm sure.
post #1677 of 2883
Assuming that you have properly calibrated the mic, and also assuming that the screen shot was taken in a "quiet" room, then the 70.6 reading is indeed your noise floor.  This seems high to me.  One possibility is that the calibration was not done correctly.  Another possibility is that your SPL meter isn't working properly (what make/model do you have?), or that your laptop's internal circuitry is "noisy".  A third possibility is a low frequency noise that isn't readily audible, but is being picked up by the mic (i.e. the noise floor really is 70dB).
Let's quickly review the calibration procedure:
- Place the tip of the SPL at the same place as you would place the UMM-6 (ear height at the ML), pointed at the ceiling, set to C weighting, slow response.  Make sure the battery is OK.
- Generate the calibration test tone (I use the sub tone, the other one is OK as well).
- Watching the SPL meter, adjust the master volume on your AVR until the SPL is reading the desired output level (I use 80dB, which on my AVR is a MV setting of -14).
- Now replace the SPL with the UMM-6, with its tip in exactly the same spot.
- With the calibration tone still playing, and the AVR MV still at the same value, enter the SPL reading you had on the SPL meter (80dB in my case) into the SPL Calibration Reading box, and click Finish.  The UMM-6 is now calibrated.
- To test the calibration, click Calibrate again so the test tone is playing, move the input box out of the way, and observe the reading on the REW SPL--it should be fluctuating right around the value you entered in the previous step (80dB in my case).
Now let's test for low frequency noise in your room:
With the microphone in place at ear level at the MLP, open the real time analyzer (RTA) in REW.  Adjust the graph limits to show 15-20,000, lower limit 0 and upper limit 100.  Click the red button to start the RTA display.  You should see something like this:
If there is indeed a 70dB noise floor in your listening area, then you should be seeing spikes that reach the 70dB level.  In the example above, my noise floor is showing to be about 50dB.  Notice those annoying spikes starting at 1kHz, which are caused by the electronics of the mic or USB interface, a topic of discussion a number of pages back.  Also note that the noise floor is being caused by something around 10Hz, which is inaudible.
Please re-calibrate the mic, perform the RTA measurement, and report the results.
Is there anything in this discussion that needs to be added to the Guide?
post #1678 of 2883
Perhaps only that little bit of marginally useful info after "Now let's test for low frequency noise in your room:"
post #1679 of 2883
Great post Jerry! That bit about the noise floor is very cool - using the RTA is something I never thought of. Will make it easier to track down any offending sound producers.
post #1680 of 2883
Recalibrated the mic at 80 dBs and you were right. Here's the new reading...
Thanks. I'll test for the low frequency noise tonight using RTA, as you suggested. This would be helpful in the Guide.
