Feri, I assume you missed the post on the previous page where I have a quick example of the kind of thing PEQ can do to a post-Audyssey curve. Here they are again:
Which of the above two curves would you prefer in your system? The first one (Audyssey alone) with the evident problem from 60Hz to 200Hz, or the PEQ one where that problem has been fixed?
You are just arguing for the sake of arguing again I think, PEQ has an undeniable purpose, as does Audyssey. Neither is perfect. Using both achieves more than using just one.
Can you please post the REW graphs of your Audyssey-corrected system so we can see why you are so sure it has done such a perfect job in your room and needs no further attention? Just your centre channel will be fine, or your sub - anything will help us see why you are so convinced Audyssey is all that is required.
