Originally Posted by
djbluemax1
Keith, yes, the XLR outputs are typically higher than the RCA. You can find the output ranges in the Onkyo manual, and the input ranges in the Emotiva manuals.
Some amps will compensate for the higher signal level, some don't. I don't recall how the Emos handle it.
Max
Thanks Max. I am using the PEQ to attempt to goose the subs' response, so the Emo's aren't relevant. Currently I use the 5509's RCA sub outputs into the Submersives via the patch lead that Mark supplies with the subs - IOW, 5509 RCA out into SubM XLR in. (I did it this way mainly because my sub interconnects are in-wall and although I can change them, it is a PITA to do so. As there is no qualitative difference between RCA and XLR in my case (shortish runs, no noise issues) I decided to stay with the RCA interconnects and just use Mark's patch cord to connect the SubMs).
For simplicity, and in order to keep the sub gain trims more or less where they are, I'd prefer to stay with this arrangement, but the Behringer only has XLR (and 1/4inch jack) balanced outputs. I seem to have two options:
- I could go from the 5509's RCA sub outs, via a patch cord, to the Behringer's XLR inputs and from the Behringer's XLR outputs to the Submersive XLR input.
- OR, I could go directly from the 5509's XLR sub outputs to the Behringer XLR inputs (Behringer outputs remaining the same for both scenarios.
I am hopelessly lost as to what the differences would be and what effect, if any, they would have. As my SubMs gain controls are already practically at 0dB, I don't really need a higher input level raising the sub output volume any more (although I can compensate via the 5509's trim controls, but I am already at -6.0dB and don't really want to drop down much below that. I can also control the gain of the Behringer of course to compensate for additional output voltage of the XLR connections. Am I right in thinking that if I use the RCA outs on the 5509 and the patch cords to the Behringer's XLR inputs that the gain issue will be irrelevant, or is this a bad idea for reasons as yet unknown to me?
As you can see, I am in desperate need of advice here. What would you do? Many thanks...
