Originally Posted by
Martycool007
Ok, so I am confused. Is the mic from Minidsp all that is needed to do measurements in REW without having to buy an external sound card and mic pre-amp with phantom power? Are there any other usb mics that work with REW hooked up to a laptop that does not require an external sound card or mic pre-amp? If so, what are they, ie brands and models?
Last set of questions, Do these usb mics from the likes of Minidsp already come pre-callibrated? I already have a spare Behringer EM8000 that I have never used, could I send it to CSL and have it callibrated? If so, the only other things I would need would be a mic pre-amp, such as the Behringer Xenyx 502, and an external sound card, such as the...(need cheap suggestions)...
Oh and I almost forgot, what is the ASIO4ALL? Is this a sound card, or what?
You will not need an external sound card with a USB mic, and according to what we have heard, the USB mic is pre-calibrated. Other USB mics include the UMM-6 and the OmniMic. To use the EMM8000, you would need an external USB soundcard and a device to provide phantom power. I use the Soundblaster X-Fi and the Behringer Xenyx 502 which, IIRC, represent a combined cost of approximately $100.
The ASIO4ALL is a driver that enables using a laptop's HDMI connection to send signals to the AVR. On recent laptop hardware, you will have 8-channel support with an HDMI connection, allowing REW to measure individual channels, unlike a stereo setup, which is limited to testing left, right, center, and subs. IMO, there is marginal value in testing the other channels, but the HDMI connection makes the whole setup much simpler.
