Should the reason for hum be misunderstood by some doesn't mean it is neither there, nor is it negligble.Hope this helps to clear up matters.
Edited by mogorf - 1/24/13 at 5:33pm
Â
Here's what my sound control panel looks like:
Â
Â
Only the Speakers / HP is "configurable" (Headphones is greyed out):
Â
Â
Then I get this:
Â
Â
From here I can only output sound to one speaker (Left). I saw you made reference to something about matching which mono signal you are connected to but I didn't quite understand where I needed to check this?
Â
I have to go now...I'll save the REW portion for tomorrow. Thanks!
On a second note, this questions how accurate the frecuency scale of REW is. Any thoughs welcome.
Â
Great news. You will have yours a good two weeks before I get mine - which is the right way around :)
Feri, if there is a genuine mains hum at 50Hz or 60Hz, caused by a grounding problem, it will be heard through the speakers. Those frequencies are clearly audible. But that is not a REW problem, although it does need solving of course.
Â
If there is a 50/60Hz spike showing on the graph but it is NOT audible, then it is something being generated purely by the laptop and not making it through to the speakers. If it cannot get through to the speakers then it cannot be measured by the mic. Running the laptop on battery power solves this issue.Â
Â
IOW, if you can hear the hum, so can the mic. If you cannot hear the hum, then neither can the mic. So if the hum is present in the graphs but not audible, where can it be coming from? Answer: the laptop. In this case, the 50/60Hz spike can be ignored as an anomaly, or removed by disconnecting the laptop from the mains.
^ Just to add a story from my experience to this topic, I had a laptop that had a noisy audio subsystem. In this case, it wasn't a current-induced hum, it was a scratchy static sound caused by a failing component somewhere. Needless to say, this laptop was completely useless for taking REW measurements, and forced me to purchase a new one.
Â
So, if there is any question as to whether the laptop itself is adding unwanted signals or distortion to the measurement loop, it's a good idea to test it out. On the output side, listening to sound coming from either the speakers, or by connecting headphones, is the obvious test. For the input side (which was the problem with my old laptop), I conducted the following test: plug in a microphone (the Audyssey mic works fine), launch Windows Sound Recorder (in Accessories), click the "Record" button, allow it to record for a few seconds, stop, and play the recording back. The recording should be clear, with no static or hum. In the case of my old laptop, I could hear the scratchy static in the playback.
You could have a stereo cable. You need a mono cable, which will send the signal to both channels.
Â
Guys, sorry if I started us down a path of troubleshooting cables/adapters. It is very possible that I have an issue with my cabling that I didn't have time to troubleshoot last night. I have some new cables arriving today that should eliminate this as a possibility. I had a couple hours last night and decided to dig through my junk cable box and found an old stereo Y adapter that came with a Mac that I owned in the early '90s. The Y adapter cable is from an old subwoofer with L and R analog RCA inputs so I figured it would work.
Â
In any case, I've highlighted the section of the manual that I was referencing in my previous post with respect to "assigning" which channel the mono signal is output:
Â
Â
I'm sorry if I missed it in the REW setup section but I didn't see where this should be assigned.
Â
Also, any idea why a monophonic short sine sweep would be playing through my surrounds when my prepro is in PLIIx Movie mode? I'm also wondering if my trouble outputting to both channels is somehow related to how my AVR is processing the signal?
Sorry, it's a mono cable, technically (I think) a "splitter." It's a Y, with the mono signal going to two outputs.
I don't think it looks different from a stereo Y, it just works differently (wired differently inside).
I've had mine for years; I probably got them at RS.
This, I think:
This, I think:
Â
Well, isn't an RCA jack mono only by definition so unless the single end is something other than an RCA jack (e.g. a 2.5/3.5mm stereo jack), it should be a mono cable?! At least this is the premise I was working against! Like I said, I'll have the proper cabling later today so I can confirm if it's the cable or a setup issue in Windows/REW later today.
This, I think:
Â
That cable will work as well.
Â
Edit: Except the end of the cable has two female connectors. You need male connectors to plug into the AVR....
Â
Â
Â
Â
Â
Â
Here is where you specify the channel:
Â
Â
Let's assume for a moment that you have it cabled correctly. The mono REW signal is output over the audio cable to the RCA Y-cable. If you plug both sides of the Y-cable into the left and right front AUX IN connections on the AVR, you are now feeding a mono signal to both the left and right channels. If you set your AVR to Stereo (not Direct, which disables bass management), then the mono signal is output to both the left and right main speakers, as well as the sub(s), assuming your left and right speakers are set to "small". If you want to test only the left or the right speaker by itself, simply unplug one side of the Y-cable.
Â
Now, with this same setup, if you change the AVR to PLII Cinema, the dual mono signal will be combined and output from the center speaker only (the left and right speaker signals will be down by 60dB, so this is effectively no signal at all). There should be no signal coming from the surrounds. If there is, then something is wrong.
^^^^ Thanks for the clarification. Can you think of anything I should check on the PLIIx issue? I've got 2 amps power 7 channels. One amp for L and R and the other for the center and 4 surrounds. When I play a left or right channel short sine sweep from the OM test track, those channels play correctly. It's only the monophonic short sine sweep that plays the surrounds as well?!
Â
PLIIx will place any signal that is common to the R & L channels into the centre channel. A signal which plays only in the L or R channel will only be played from the corresponding speakers. However, PLIIx is an upmixing DSP so it also matrixes everything from 2.0 up into 5 or 7 channels. It follows then that a mono signal played through the R & L channels will end up giving some content to the surround channels, if only by way of leakage.
Â
Please note that I am no expert on this and I would get corroborating views if possible. If Roger Dressler is around he will give the definitive answer.
Â
It is not an REW issue. Not being familiar with your AVR, and how you have the PLII surround parameters configured, I can't provide any guidance on how to fix the issue.
Â
However, there is a simple work-around. While you are using REW and measuring the center channel, simply disable the surround speakers in your AVR's speaker configuration menu. Doesn't hurt a thing, and has no effect on the Audyssey calibration (on or off). Turn the speakers back on when you are done measuring.  Make sense?
Â
Â
Â
Well, I am not an expert at anything, Keith, but I do know how to run a test. ![]()
Â
I sent the REW mono test signal to my AVR's front left and right AUX IN connections, set the AVR to PLII Cinema, and used the REW signal generator to generate test tones at several frequencies. The tones were audible primarily from the center speaker. Since I use an XPA-3 to drive the front three speakers, I switched it off in order to isolate the surround speakers. There was a faint tone coming from the left and right surround speakers (I would say -30dB or -40dB, but I didn't measure). The sound was so low that I didn't notice it when the center is playing. I tested with Audyssey off and on, and even with DEQ on.
Â
I suspect jkasanic is hearing a more pronounced sound, which indicates something may be wrong. BTW, in PLII Cinema mode, there are not any configurable options that would affect the loudness of the surrounds (at least not on my 4520).
Â
Â
Â
Â
Â
Â
Good test AJ. In that case, if the sound from the surrounds is very loud, then something seems to be wrong with the configuration of the system.
Â
Â
Â
Â
Â
Â
Â
Thanks AJ and Keith for trying to help me troubleshoot this issue. Since Keith also has OM as well as an Onkyo equivalent to the DHC-80.3 in the 5509, I was wondering if he might be willing to throw in the OM test disc, set his Onkyo to PLIIx (although I suspect his will default to PLIIz since I believe he has height/wide speakers as well) and play track 2 to see if the sounds from the surrounds is higher than the -30 to -40 dB that AJ was reporting from REW (just by listening of course, no need to break out the OM Mic unless you're ready to try the new REW beta and start measuring with it until your EMM-6 arrives)? I don't have my REW setup working just yet (hopefully tonight or tomorrow as there are some issues that I encountered...hint: Java exception errors in the REW configuration screen) so the PLIIx issue is exclusive to the OM test disc tone generating method. I didn't bother to measure the output of the surrounds without the center channel but I will do that during my next measurement if we aren't able to determine the setup issue I have currently.
It is. It's what I use. I bought a MobilePre (http://www.musiciansfriend.com/pro-audio/m-audio-mobilepre-mk-ii), used/open box. Follow the directions in the original REW thread on HTS for cabling.
Since it would cost as much as the USB mic, is more of a PITA, and isn't as accurate, I suggest you just get the new mic. You'll still use the SPL meter for dB calibration.
Michael
Â
Â
Â
Â
Â
Â
Â
Â
Sure - I will do that for you. Will report back later.
) until the hum goes away.
