AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How... - Page 27
post #781 of 2904
Originally Posted by AustinJerry View Post
Originally Posted by jevansoh View Post
It can be calculated and is different for every room. It has to do with the height of the room, the mode that creates, and when you calculate that, you can figure out the placement.
There is an Excel spreadsheet on the Harman web-site that allows you to input your room dimensions and it will show you, graphically, where your modes are and at what area, both graphically and printed out in specific hz vs ft and inches where the modes are strongest, weakest, and mid-way.
It's pretty neat and a great tool to be able to visualize best placement for speakers/subs and listeners in the room.
It's a starting point, of course. You will have to measure and it won't be perfect as it assumes true boundries of thick concrete walls for instance, where you may actually have openings, or only one or in some cases two layers of drywall and mass is critical when trying to calculate modes, as is symmetry/rectangle room, but it is always pretty close and I use it a lot.
I'll post the link when I have time to dig it up later unless someone else beats me to it.
If I knew the height of the ceiling and the height of the listener's ears, I could tell you approximately where to place the sub vertically to negate the effects of the null in that position, but would need more detail.
Find that spreadsheet on the Harman web-site and you can see for yourself. I got lucky and in my case only had to raise a sub (it only took 1 and I have 4) 15" off the ground and I already had a 12" riser for the second row in a dedicated theater, but it can be done in any room.
--J
OK, here are the results for my room:
What is missing (at least for my understanding) is how to actually use this as a guide for speaker placement.
Take my listening room as an example.  I have my room oriented so that my front speakers and my TV display are on the width of the room (19' 6"), the middle graph above.  So, what does the graph tell me about the recommended horizontal position of my left and right speaker?  How about two subs placed on the front wall (BTW, the two subs are placed at the 1/4 and 3/4 distances).  And should the MLP be exactly in the center for symmetry?
Does the top graph suggest how far from the front wall my speakers should be placed?
And does the bottom graph suggest whether I should raise a sub off the floow, and by how much?
This is how my front speakers and subs are configured now:
pages 7-18 here
http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/LoudspeakersandRoomsPt3.pdf
Were sufficiently difficult to make me stop reading but should provide some insights.
Def gunna attempt to read that a couple times.
Edit: fixed link
post #782 of 2904
Originally Posted by dstew100 View Post
pages 7-18 here
Edit: fixed link
Typical, a 33-page technical document to slog through looking for an answer.
post #783 of 2904
pages 7-18 here
Edit: fixed link
OK my brain won't stop toying with this even when I try to stop so lemme take a very wild swing into the dark at this. It's fine to point and laugh but helping me understand is preferable. First off I will point out what I know is blatantly obviously missing from this thought process I'm about to lay out... It does not take into account ear height which clearly matters, I'm just not understanding how to account for it.
-The metric system is better then what I was taught but I did it in feet and inches anyway. I think we should poll on this topic.
-Your actual height is 10'
-The calculator assumes perfectly stiff and reflective floor/ceiling/walls, I assumed yours are not. (like the paper does in one example)
-If your room's height were 12'8" there would be a 2nd order mode at 89Hz (wow I made the tool have your null). Your "Acoustical Height" is 12'8"
-WTF, this thing is not only using U.S. customary units, it's rounding off to the nearest quarter of the foot then displaying decimal feet????
-The paper claims putting the speaker at the distance laid out by the mode calculator will make that mode not be energized
-If your floor were perfectly stiff and the added acoustical height is completely caused by the ceiling, then the correct sub height would be 3' (well with the inaccuracies and rounding maybe 3'2.5") from the floor to tame the 2nd room mode in the height dimension
-If your ceiling were perfectly stiff and reflective and the added acoustical height were entirely from the floor, then the correct sub height would be <1 foot from the floor to tame the 2nd room mode in the height dimension.
Conclusion
-Try several heights from it's current height up to 3'3" measuring along the way, if you're on a concrete slab, start at 3'3" and work down.
-Temporarily raising it up on stuff for a measurement shouldn't be that bad, finding something permanent you can live with ascetically is a different story.
OKOK, point and laugh, or help if you can help me understand.
Edited by dstew100 - 1/29/13 at 9:43pm
post #784 of 2904
I would look for where pressure is at a minimum (nulls) and place my sources of pressure (subs/speakers) at those locations for cancellation. Like slicing off the top of a mountain (peak) and flipping it over into a valley (null) to get a flat landscape (high pressure meet low pressure).
Since you're using 2 subs on the front wall, from your chart it looks like placing them at 1/4 and 3/4 of room width will help deal with the 2nd width mode at 58Hz (within the subwoofer's range). But you've already placed your subs there.
Above the crossover point you're using 3 speakers on the front wall, so from your chart it looks like placing them at the 1/6, 3/6 and 5/6 points of room width will help you deal with the mode at 87Hz (might want to try lowering the crossover to 70Hz so it doesn't interfere).
This assumes that both subs will be playing the same bass (which they will be) and all three speakers will be playing the same bass (should be, most of the time, depending on how it was mixed, and other caveats). OK, so you can't cancel all the problems with placement alone, but at least it helps address a couple of the most audible ones.
Chances are you'd get smoother frequency response sitting at 1/3 and 2/3 of room width. But who wants to do that. I prefer to sit in the middle, probably sacrificing some smoothness for left-vs-right consistency in soundstage and imaging. Not having the latter would bother me more than the former (which can be addressed with treatments and EQ).
post #785 of 2904
Then just read page 14.
post #786 of 2904
However, a lot of people that follow this philosophy stop there. The fact is, all reflections are NOT bad! In fact, they are necessary! Depending on the size of your room and your level of commitment, anywhere from about 12-20ms (larger rooms up to 25ms) should have a termination of the effectively anechoic space we are creating by reducing the early reflections to -20db in gain relative to the direct sound. There should be reflections after somewhere between 12-20ms but they should be diffuse and dense and not just one or two here and there.
J, there's one thing I have never understood wrt to the above. I can see that some reflections can be a good thing for stereo setups because without them one will never get the sensation of a large room and so on. But why are some reflections necessary when we have 7 or 9 or even 11 channels of sound in a HT room?  Isn't any required ambience already recorded into the track and reproduced through the appropriate speakers as required?
I remember Max referencing a movie I am familiar with - Cliffhanger. At the beginning of this movie there is a helicopter scene. If you engage Audyssey DSX Wide, which attempts to simulate reflections in order to attempt to recreate a 'concert hall' space, the helicopter sounds perfect for a helicopter recorded in a large hangar. The problem is, the helicopter is actually outdoors. The additional reflections (simulated here, but would it be any different if they were real reflections?) destroy the intended effect of a helicopter flying outdoors.
I can see the benefit of having some reflections for music and for stereo - but cannot understand why the ambiance recorded into the material is not all we need when we have multiple channels for movie sound reproduction. I am only concerned with movie sound as I do not play music in my HT room. If this is regarded as OT, please PM me if you have time. Many thanks.
PS. I followed and understood all the rest of your post, so I am making progress! smile.gif
Well Keith, I suppose if 100% of the content you listen to is multi-channel (5 channel or more) and the majority of that content keeps the surrounds active providing that ambiance, then you have a point and I concur that the model which we've been discussing thus far (LEDE/RFZ) is the most suitable and a model approaching NE (Non-Environment) would probably be most suitable.
In this case we'd simply suppress all the reflections to a minimum of -20db from 0ms to infinity without a termination or return.
We'd have an effectively anechoic room at this point and it would not be enjoyable to listen to 2-channel music or even movies that didn't provide ambiance/content in the surrounds, in my opinion.
Your case is a bit different. You actually DO have a dedicated 2 channel room and a dedicated room where you ONLY watch movies.
So... In your case, which I doubt we'll come across very often in this thread, I might recommend just that for you! You won't achieve a true NE room, but you can approach it, which is all we're trying to accomplish in this thread anyway...Getting people on the right path, provide the info and the tools necessary to achieve the goal, but realizing few will take it all the way.
For most folks though, they either don't have a dedicated room at all, in which case it would be pretty boring and lifeless and wouldn't work at all if, for instance, it was a living room where you hoped to have quiet conversation, or they are lucky enough to have ONE dedicated room which must serve a mixture of 2-channel and HT.
When you're listening to two channel and only have those 2 speakers and the room itself to do all the work, in my experience, it's best to account for the needs of those two channels and let the HT fall into place, especially if the ratio of music listening to movie watching approaches 50/50.
This is why there is no one right answer though. Everyone's situation, needs, and goals are different.
This is what makes it difficult if not impossible to put a nice pretty bow on this because we don't start with a neatly wrapped package.
There are different models to get different results and what works for one doesn't work for the other, which is why I hesitate to do what Nyal did and say, This should be your target. Period.
I know he means well, but I just don't believe it can be summed up that easily because of different uses for the rooms and different tastes, not to mention WAF, budget, etc.
So a more one on one approach is probably needed.
There are, however, certain things all the models have in common and only a few of which are drastically different, one of which is this talk about reflections.
Even in the industry there is a wide variance on what is "right" with Floyd Toole himself going against what has been pretty standard for decades now and basically saying there aren't bad reflections and most people prefer them.
While I don't agree, I do agree it's possible that a certain subset of folks that are only used to hearing rooms with lots of reflections and haven't truly experienced a well treated critical listening room might think they want that because they don't know anything else.
There isn't a line in the sand answer here, though, Keith.
What's right for you isn't for the next guy and this was a great question to bring up early on because it shows just how diverse we and our needs truly are.
I'm more than willing to help you achieve whatever model you decide though, to the best of my ability, and as time permits.
To sum it up though, yes, I do believe for you, you need to either decide to try it both ways (depending on how much time/patience you have) or read up on the difference between LEDE and NE and pick one, stop thinking about it, and start working towards it.
Hope this helps,
--J
Great help thanks, J. My room has quite a lot of treatment and it definitely sounds 'deader' than the sitting room next door, but the clarity and imaging is amazing since I installed the treatments. Whenever I demo it to anyone, the one thing they all say in common is "it is so clear".  I don't mind a dryer room I think - remember it is just for HT. When my mic arrives I will be able to take some measurements and see what the decay times etc really are. Thanks for all your help so far - it is truly appreciated.
post #787 of 2904
I'd like to see your FR and Waterfall with and without Audyssey, Keith. wink.gif
And you will, J, once my mic arrives and I have learned how to use REW, at least the basics.
Although I do measure without Audyssey, to try to get the room as good as I can without MultEQ, I always make my final graphs with Audyssey and these are the ones I rely on for my ultimate judgement of the SQ. The reason is I would never listen without Audyssey, so shouldn't my 'final' graphs be those that have Audyssey engaged - that is what I will listen to.
It's important to see both. Always. You need to know what Audyssey is doing. Unfortunately, there are times where Audyssey makes certain things worse and at times even pushes drivers beyond their limits. We won't know that without both graphs.
Also, once you get into this, who knows, you may find that you no longer need Audyssey, or at least that it doesn't make "as huge of" a difference as it used to, but most likely still "better."
We just don't know enough about your room, your goals, and what you're willing to commit to making it better yet, Keith.
I suspect pretty great things for you and your room though.
I only wish you were close enough for me to meet you and hear it in person, though.
--J
Since I installed my room treatments, I do find that the difference between using the system with Audussey ON and Audyssey OFF has diminished a lot. Before, the system was unlistenable with Audyssey OFF - now it is listenable but not as good as with Audyssey ON. But the difference is definitely smaller.
I wish you were close enough for you to hear it in person too!!  Oh boy, yes. I am all alone on this - no friends are interested to any serious extent, there is no available professional help locally and the UK forums don't go into anything like the depth we are experiencing here. But we're doing OK by remote control so far... ;)
post #788 of 2904
I am considering adding a dedicated section in the guide covering how to configure REW measurements, and how to post the results.  I'm not sure if I have it all correct now, but we can review and correct the guidelines once they are captured.
Excellent Jerry!  On page 1 of the thread I posted the HTS guidelines for REW measurements. At one stage there was talk of sticking with their guidelines for compatibility. I think we may have moved from that position though.
post #789 of 2904
@ Amir
So am I correct in concluding that there is no hope and we should all stop generating ETC graphs?
And regarding your reference to the link on Whatsbestforum, yes, I have attempted to comprehend the theory that you presented in the thread, but it is over my head.  Perhaps we are moving in the direction of comprehension, but we aren't there yet.
Remember, Jerry, you are talking to someone who argued about ETCs for page after page in another thread. And then it was discovered he didn't even know what the E stood for ;) I guess the cut and paste let him down.
post #790 of 2904
Thanks for the quick response.  You had me worried there for a minute.  The 0.5ms reflections are a concern but until I get my UMM-6 mic and load the proper calibration file, I'll reserve changes to simply adjusting the L/R speakers inward and modifying the toe-in to avoid the screen frame or removing the grilles (although I can't remember exactly what these foam blocks do but I recall something about leaving the grilles installed as a result?!):
Time differences!  :)  I leave the grilles on on my S150s - they are pig-ugly enough without peaking under their skirt. I'm not sure it matters much - you can run a sweep with and without grilles and see if you are finding any notice difference in FR. I would doubt it would be audible.
Re stands - yes, the official M&K stands are rarer than hen's teeth. You can wall-mount the speakers using Omnimounts you know.
post #791 of 2904
Thanks Keith!  The question about the grilles was regarding some early reflections (0.5ms) that showed up in my measurements and whether or not the cabinet was the source.  I suppose we'll answer this soon enough once you start measuring.
post #792 of 2904
Sanjay, thank you for your input.  Your assessment is very accurate.  I placed the front subs at 1/4 and 3/4 several months ago, which indeed resulted in smoothing the 58Hz mode.
However, placing the left and right speakers at 1/6 and 5/6 would represent a compromise that I am not quite ready to do.  I have a DSX 11.1 configuration, and have limited space for the placement of the DSX Wide speakers.  The Audyssey guidelines are to place the mains at a 30-degree angle from the MLP, and the wides at 60 degrees.  In my current configuration, the mains are at 26.5 degrees, and the wides are at 50 degrees, which is already somewhat less than ideal.  If I were to move the mains out to the 1/6 and 5/6 positions, they would be practically next to the wide speakers, thus impacting the DSX effect.  I could temporarily move the mains and take a fresh measurement, just to see the effect it would have on the 87Hz mode, which I probably will do when the USB mic arrives.  It is unfortunate that we are faced with these compromises.  Perhaps it's time to build a new listening room!  wink.gif
Note that the last measurement that I took clearly shows the mode at 87Hz, although I guess it could have been worse than down 5dB.  Note also the 170Hz null associated with the ceiling height.  Based on the model, I guess I could try raising one or more of the subs 1.75 feet off the floor, but I'm not sure that raising the subs (which are crossed over at 80Hz) would address this issue.
Now that I understand the Room Mode Calculator spreadsheet better, I does seem like a useful tool.  Perhaps others in the thread will try it out as well.  Thanks again.
post #793 of 2904
Conclusion
Read my response to Sanjay.  Now that I understand the Room Mode Calculator a little better, I understand that placing a speaker at a null point is the objective.  As Sanjay observed, the sub placement at 1/4 and 3/4 addresses the 58Hz mode.  However, I don't come up with the same calculations as you do for the amount to raise the subwoofer.  If you look at the modes associated with room height, they are 113Hz, 170Hz, and 226Hz.  Of the three, only 170Hz seems to be an issue in my room, based on the published measurement.  If you look on the height graph, the speaker should be placed at a height of 1.75 feet to address the 170Hz mode, not 3.25 feet as you suggest.  However, I am not sure that the sub would help cancel a mode as high as 170Hz, but it may be worth testing.
post #794 of 2904
Here's a plot of my room.  I'm not quite following the how-to on the analysis.  My only real flexibilty is with sub placement but even that's limited due to WAF.  I'm still planning to do another sub crawl when my USB mic arrives but any thoughts based on this plot?
post #795 of 2904
This has probably been mentioned before but it seems to me that having an overlay function in REW for calculated room modes would be helpful.
Something like a bar graph which could be superimposed or under the actual graphs in REW and you may be able to correlate modal issues directly to measured issues.
Shouldn't be very hard to do right?
post #796 of 2904
^^ The first step would be to run fresh frequency response measurements when you get the USB mic.  Then, analyzing these measurements, we would identify dips in the response that are associated with the room modes, I.e. 40, 81, and 121Hz for the width, and 31, 62, and 93Hz for the length.  One or more of these frequencies might be an issue in your room.  After we determine that, we would look at your speaker positions to see if we could move any of them into a null associated with a problem frequency.  So, for example, in my room there was an issue at 58Hz.  I was able to move my two subs to the 1/4 and 3/4 positions along the front wall, which are the nulls associated with the 58Hz room mode.  The result was that the null at 58Hz all but disappeared.
Of course, the issue is whether you are lucky enough to be able to find speaker positions that address a room mode, and are acceptable from other perspectives, like aesthetics or the WAF.  Make sense?
post #797 of 2904
Treat that point on the hard surface with a temporary treatment.  A square of R-30 insulation (i.e. "pink fluffy"), available at your local hardware store, is a good temporary treatment.
Hi Jerry, is there a recommended square size and how thick of R-30 to get?
post #798 of 2904
Where do I find this Axial Standing Waves graph in REW?
post #799 of 2904
It comes in a roll, and I believe it is ~9 inches thick.  A roll allows you to cut a piece that fits the area you are testing.  You can layer two pieces for an 18" thik test as well.  Be careful with the pink fluffy when you are handling it.  Try not to inhale any particles--it is nasty stuff.  Here is a picture of the R30 when I was testing how to treat my back wall:
post #800 of 2904
The Room Mode Calculator can be found here:  http://www.harman.com/EN-US/OurCompany/Innovation/Documents/Calculators/Room%20Mode%20Calculator.xls
The second screenshot in my post is just an Excel spreadsheet that I created.
post #801 of 2904
Makes sense...thanks for spelling it out.  Now where's my e-mail from Herb! tongue.gif
post #802 of 2904
Remember, Jerry, you are talking to someone who argued about ETCs for page after page in another thread. And then it was discovered he didn't even know what the E stood for wink.gif I guess the cut and paste let him down.
You rely too much on random claims on the Internet Keith. Here is the post in question: http://www.avsforum.com/t/1413173/does-sound-sounds-better-in-a-room-full-of-furniture-and-stuff-or-without/720#post_22260722
Originally Posted by amirm View Post
Originally Posted by dragonfyr View Post
First of all, "E" does NOT stand for "energy", but I find it humorous that you are still tilting at that 30 year old windmill.
AES paper:
The Analytic Impulse and the Energy-Time Curve: The Debate Continues
D. B. (Don) KEELE, JR.
AES Paper:
Uses and Abuses of the Energy-Time Curve*
JOHN VANDERKOOY AND STANLEY P. LIPSHITZ**
AES Paper:
USING BASIC ENERGY TIME CURVE (ETC) MEASUREMENTS
Don Davis, Joe Martinson
AES Paper:
Determining the Acoustic Position for Proper Phase Response of Transducers*
RICHARD C. HEYSER
"The amount and phase of this arrival pattern of energy is more accurate displayed in the energy-time curve[3]”
Reference "3" is the original paper where Heyser discussed the concept of ETC:
[3] R. C. Heyser, “Determination of Loudspeaker Signal Arrival Times, Parts I-III,” J. Audio Eng. Society
AES Paper:
Controlling Early Reflections Using Diffusion
JAMES A S ANGUS
"An idealised energy time curve for a room is shown in figure 1"
You were saying?
Obviously you are not aware of the other earth shaking discovery that the proper term for the ETC is the ENVELOP Time Curve. A modification made, not by Toole, but by Dr. Patronis and Don Davis MANY years ago, much in the same way that they corrected we early participants in the seminars that the term "time alignment" is improper slang, seeing as how one cannot align time but that we can only align signals with respect to time, hence the proper terminology being "signal alignment".
You are taking tea to China. Look at the term and explanation I used in post 176 of this thread:
ETC is designed to make the impulse response easier for humans to interpret by filling in the valleys with the "envelop."
Now let's look at how you have been referring to it:
For energy above the Schroeder critical frequency, fc, where energy behavior changes from modal standing waves to focused specular waves, we use the impulse response convolved into the Energy time curve or ETC response
You mean aside from the fact that what you have posted is instead a frequency domain spectrogram and not a time domain ETC response that has absolutely nothing to do with that to which we were referring and is even more unusable for identifying and analyzing specular energy characteristics???
Localhost claiming the same:
Originally Posted by localhost127 View Post
. the ETC is the time-domain measurement for the specular region - to identify how specular energy is impeding the listening position. from the direct signal, to sparse high-gain reflections incident from room boundaries, to later-arriving reflections, to the eventual decay of the energy until it is fully damped. gain with respect to time.
Let me add another reference since we are talking about REW. Here is the introduction to REW in the help file: http://www.hometheatershack.com/roomeq/REWV5_help.pdf
"Welcome to REW
REW (Room EQ Wizard) is a Java application for measuring room responses and countering room modal resonances. It includes tools for generating test signals; measuring SPL; measuring frequency and impulse responses; generating phase, group delay and spectral decay plots, waterfalls and energy-time curves;..."
Clearly you did not read the thread you are talking about Keith or per above, the help file for REW. Even if you had, it is outside of the spirit of this thread to agitate members instead of focusing on the technical matter at hand. If you think ETC is useful, explain how and we can discuss it. Show me that I am wrong that way. You can start with addressing why the energy from the speaker is the same in all directions. Stand behind your speaker for example. Does it tonally sound the same or does it sound like there are less highs? How about to the side? If what you hear is different, then what the microphone "hears" is also different. And that impacts the levels displayed in the impulse response. It has to: the math says so, the listening tests say so, and the experts that do this for a living say so. I open to you disputing it but not with response like above.
post #803 of 2904
Just so there is no confusion, ETC does not actually measure the true energy of the system/reflection. The context above was that I demonstrated that fact and then folks were backpeddling, claiming not only do they not associate it "E" with energy but no one else does either. My post above shows that both positions were false.
If you don't get a headache reading math and signal processing equations smile.gif, here is a detailed post I wrote in the other thread explaining what it is and why it can't represent true system energy: http://www.avsforum.com/t/1413173/does-sound-sounds-better-in-a-room-full-of-furniture-and-stuff-or-without/210#post_22185014. So this is another minor reason to not use ETC.
post #804 of 2904
So I went to that thread and the majority of what I saw appears to be argumentative in nature;
Controversy seems to be a key element - not sure why?
post #805 of 2904
Or turn your's 90 degrees.
post #806 of 2904
I would rather see this thread remain true to it's name.
In other words; a positive tutorial to help one come up to speed with an easier to use REW setup.
That said; a Big Thanks to the positive contributors here: AustinJerry, Keith, and numerous others.
post #807 of 2904
Sigh, if only I had that choice, Sanjay.  One side of the length wall consists of a brick fireplace flanked by a window and a glass french door.  The other side is really only a half-wall opening out to the entryway of my home.  Obviously not a dedicated home theater, but I make do with what I have.
post #808 of 2904
amir,
were you able to google the b&K domain map as of yet? maybe you could produce a little book report on it like you do all of the other topics here. keep going, we almost think you're an expert with actual acoustical experience!
remember, we don't need it in your own words. if you're unfamiliar with a topic, just google it, copy-paste from toole, present it in a nice fashion, and everyone here will think you're an expert. classic salesman tactics at play; what's new?
"Localhost claiming the same: "
uhh, yeah - specular energy. not specular envelope. i don't think you even understand the terms appropriately to comprehend the laughable nature of your assertion. nor does your google copy-pasting take into account history and development. oops.
how are those baby diffusers doing in your company's showroom, amir? tongue.gif
Edited by localhost127 - 1/30/13 at 10:31am
post #809 of 2904
Nyal, you hear that?
so now it's a "minor" reason not to use the ETC. contrasted with his early commentary that he sees no reason for time-domain perspective/analysis in residential rooms in that old thread. nor did he even understand what the X-axis was related to! clueless without his book reports to fall back on for reference/copy-paste.
it is comical how much amir sees the ETC tool as a threat. he goes out of his way to illustrate improper ways to utilize the tool and claims that is no use. his entire business model is focused around toole and toole's papers - even though toole himself insists it is a matter of taste!
i've never quite encountered any user who literally sees an acoustical measurement tool as a threat. this is what they teach in CEDIA?
post #810 of 2904
Going by your chart (feels like I'm about to read your horoscope)... If you've got a single sub, I would place it in the middle of the front wall, below the centre speaker. Two subs, place them 42 inches in from the side walls. Place the L/R speakers 28 inches in from the side walls. Is any of that do-able?
