Tell me Jerry, in case of Audyssey setup, how does the Audyssey mic know how to set the speakers trims to reference level? Is there a need for a separate SPL meter or not? I can't remember anything mentioned in the setup guide to this extent! Case not closed, let's discuss till we can come to agreement! Deal?
I don't know what the Audyssey setup has to do with our discussion, Feri. Back on topic, I presented you with a response from John M., the author of REW, saying that a microphone calibration is a required step for all mic's other than the UMIK-1, which enjoys in-built support in the current beta version of REW. For anyone else, this would be proof enough. Why is it not good enough for you?
) the cost is negligible as a percentage of our total system cost. And, as you have said more than once, a SPL meter is a darned handy tool to own anyway. So whatever anyone says, anywhere, I will still be taking the few seconds to match REW with my SPL meter - that way I know I cannot possibly go wrong, regardless of which 'theory' is gaining ground on any particular day, from any particular member.
Seriously, as with any other task, when you use a tool a lot as I have, you develop more optimized workflows. If you have been using REW and are an expert in it, let's have you articulate what can go wrong. If you are new to REW and/or are not able to say what "can possibly go wrong" then we don't need to waste time and energy on it in this thread or the FAQ.
