This post for content transferred from the Audyssey thread.
I will just copy and paste for now - will tidy it all up later.
Edit: below is a rough and ready copy/paste of every relevant post from the Audyssey thread:
Hey guys,
I use REW and honestly, it couldn't be easier or more robust.
The newest version, which is of course also free, now has support for Plug-N-Play USB Mics.
You can get an individually calibrated USB Mic from Cross Spectrum Labs for about $99 shipped and there is no pre-amp, phantom power, etc needed.
So there is only one piece of equipment to buy, the mic, and it's plug-n-play, the software is free, and as mentioned in a post above, you can take one measurement, one time, and then manipulate it any way you want to get any data out of it you want and until you learn (there are several threads that go into detail about how to read and interpret each chart/graph) you can also share the measurement file so more experienced folks can manipulate it and analyze it with standard graph settings that most of us use.
You can literally plug the mic in now, tell REW which USB Mic you're using, and take a measurement in less than 5 minutes for less than $100 with an individually calibrated mic.
IMHO it doesn't get any better than this and it's by far the cheapest and most robust solution.
--Jason
Here's some more info for everyone.
While it is true that REW generates the signal internally, meaning you will have to hook your computer/laptop up to any available stereo input on your AVR, you will not need to use an external CD/DVD Player and CD/(DVD??) like you do with Omnimic/RTZ so that pretty much cancels each other out as far as I'm concerned.
There are no other "black boxes" needed. You will NOT need a full duplex sound card because you aren't using the sound card's mic input and speaker/line output at the same time, as you'll be using the USB Mic. So the built-in sound card that every PC/Laptop has works fine. (Using it this way myself on a cheap laptop)
Yes, the output/jack on the sound card is 1/8" stereo mini and Yes, the input on the AVR is RCA, but that is taken care of by a $3.00 1/8" to RCA Splitter/Y-Adapter that I bet most of you already have.
The Mic is USB and there are a few options, both of which are under $100 shipped and that should be all you need, unless you need to get the $3.00 adapter to go from 1/8" stereo plug to RCA Jack. You can actually get these at Monoprice for $1.00 or so!
The first MIC Option, and the one I recommend, is the Dayton UMM-6 USB Mic calibrated individually, by a human being (who has his own very high quality/expensive calibration mic/rig and a lot of experience) at Cross Spectrum Labs.
Here's the link.
http://cross-spectrum.com/measurement/calibrated_umm6.html
This Mic is only $90.00 and he charges $9.00 for shipping.
CSL no longer ship calibrated mics worldwide. Those not in the USA might consider the UMIK-1 which, I believe, is available worldwide.
If you are a member of HTShack, which is where most of the support for REW is and where JohnAV, the writer/owner of REW hangs out, simply put your username in the notes when you order and he'll give you $10.00 off if you order before Jan 1st! After Jan 1st, he will still give you $5.00 off!
I've found out a few more things I'd like to share. First, this mic is the same or very similar as what is offered with Omnimic and you can also purchase it directly from PartsExpress.
However, the Mic's that come with your Omnimic and this Dayton UMM-6 Mic, which you can also purchase directly from PartsExpress for about $5.00 less are NOT "truly" individually calibrated by a human, nor do they come with calibration files for 0, 45, and 90 degrees, polar responses, etc, which can come in very handy once you learn more about taking measurements and if you get serious about it and acoustics/improving your room.
The EMM-6 and a few others (old mic that a lot of people use which requires Pre-Amp/Phantom Power) also states it's calibrated and you simply go to the web-site, enter your serial number, then get a cal file however, when CSL compared their truly individually calibrated mics they found up to 5db difference!
So, please understand that the mics you think (because you were told so!) are calibrated really are not and do not match with true individual calibrations. Some are closer than others, but you won't know unless you get them calibrated.
CSL and PartsExpress both purchase these wholesale from Dayton and PE simply charges a few dollars less but doesn't do anything other than sell you the mic as it came from Dayton, however, CSL actually calibrates each mic individually at 0, 45, and 90 degrees, and does this all while charging about the same price!
There is another option, too. Mini-DSP just came out with a USB MIC but you purchase it directly from them. They ship from Hong Kong, but surprisingly, it only takes a few days and everyone over at HTShack has had a good experience so far. So since CSL doesn't get a good break on them wholesale, they don't offer them directly/individually calibrated aren't truly individually calibrated from Mini-DSP, but supposedly are very close. You could always purchase this MIC if it's your preference and send it in to CSL to have them calibrate it of course. I "think" that's around $50-$60 or so??
The latest version of REW, just posted last week, has a drop down menu selection where you can select the Mini-DSP mic (linked to a few posts back) and it's as simple as selecting the mic you're using and running measurements!
GIK Acoustics has a good video tutorial on their web-site on using REW and how to take a measurement to get started and of course there is lots of help on AVS and HTShack.
I helped AustinJerry awhile back in interpreting his results and making some recommendations and would be more than willing to help each and every one of you with anything you need from setting it up, which honestly couldn't be easier, to performing measurements, to helping you understand what they mean and what to do about them.
I love this stuff so much and spend several hours per day 7 days a week between AVS and Gearslutz which is where I have learned so much about acoustics and room treatment.
I have personally been able to get my dedicated theater within +/- 4db with NO Audyssey unsmoothed, and within +/-2 db with 1/3rd smoothing all the way from 20hz-20khz but have realized over the last year or so that frequency response is NOT at all, not even close, to being what is very important.... It's the modal decay times in the low frequencies and the ETC in the upper frequencies.
There's lots to learn, lots to explain, and I'm more than willing to help, but a lot of things simply cannot be done and understood with Omnimic/XTZ and now with Plug-N-Play USB MIC options available for under $100 and at the most another few bucks for an adapter most people already have, there truly isn't any reason I can see to use anything but REW. YMMV of course.
--J
PS If anyone wants more specific links to RatShack/Monoprice on exactly which adapter to buy or any other info of any kind, feel free to ask here or PM.
Edited by jevansoh - 12/30/12 at 1:24am
With REW(beta) and ASIO support you can direct a laptop HDMI output to drive any of the eight available PCM channels individually, or two at a time using the timing reference output channel option.
Regards, Mike.
Originally Posted by pepar
Wow, that's great! Does using HDMI output complicate creating a correction file for the "sound card"?
I created a correction using a Pre-Out connection on the AVR - with all processing disabled. So in theory the graphs should show the combined effects of processing(once re-enabled), power-amps, speakers, room, microphone(accounted for with mic cal file).
Regards, Mike.
Mike, how did you loop-back the pre-out connection on the AVR to the laptop? Pre-out is analog RCA. For a 5.1 system that means 6 analog RCA connectors. Or am I lost here? Care to expand? Thx.
One more Q. Can the loop-back be done with a single HDMI connection between laptop and AVR?
The beta REW with ASIO support and a suitable driver such as ASIO4ALL allows you to select a single input channel such as the Centre channel, then you connect an RCA to 3.5mm lead between Centre Out (Pre-out) and feed that back to the laptops analogue input, acting as the loop back. Adjust the levels as appropriate and make the correction file.
If you want to check, just select another output channel and move the RCA as well, and check that the correction is still valid. Job done.
The actual sweep testing only requires the single HDMI, but the initial loop back requires the RCA lead.
Regards, Mike.
A great post Jason - thanks. I may still be tempted (your argument is very seductive). What would I need as an external soundcard to connect to my prepro? Can you recommend one? Is it OK to connect that to the front AUX connector on my prepro? I would need a long lead as my hardware is in a closet outside the HT - what sort of lead would this be? Thanks for you help.
Bingo! I've just got it set up Guys!!!
First, make sure you have the latest version of REW (5.01 Beta 10) and the latest version of ASIO4ALL (2.11 Beta 1).
Go to REW->Preferences->Soundcard:
1. Choose ASIO in Drivers
2. Click on ASIO Control Panel radio button: in my case it shows a) Realtek and b) Inter (R) - audio, make Inter (R) audio active. Don't forget to put the check mark to: "Always resample 44.1 kHz 48 kHz".
3. In the Output dropdown menu now you will see 8 selectable channels!! Oh, yeah!! So far, so good! I'll have to find out a way to rename them, coz the channels are just numbered 1-8, anyhow in my set up it is:
1: FL
2: FR
3: CC
4: Sub
5: SL
6: SR
7: FL Height
8: FR Height
Now choosing any of these numbers will direct the test signal to the appropriate speaker.
And now:
"Timing Reference Output" dropdown menu will show the same channel number. Clicking #4 will add the sub to that specific speaker.
Cream on the cake: the Denon AVR display shows: "Multi CH IN + PL IIz" and all 8 input indicators are lit!!!!!
Laptop is hooked up to AVR with one single HDMI cable!
WOW!
Edited by mogorf - 1/1/13 at 12:32am
Another tip here:-
Channel 4 is indeed the Sub - but more specifically it's the LFE channel, and as such it runs 10dB hot - so adjust the output level accordingly when sending sweeps to it.
The other channels will still employ any bass redirection set by the AVR of course - I just switch off the sub power if I want to test a speaker in isolation.
Edited by AV_mike - 12/31/12 at 2:40pm
You do not need any external sound card if using a USB Mic because you no longer need full duplex capabilities since you won't be using the sound card for "input" (that will be the USB Mic now) at the same time as "output." The output is all you'll be using on the sound card and I haven't seen a PC/Laptop since about 1997 that doesn't have a built-in sound card, so I'm sure you don't have to purchase anything but the Mic which is less than $100.
--J
You will NOT need an "external" sound card. I'm SURE your PC/Laptop has a sound card and the one that is built-in is more than adequate if manufactured in the last 10 years or so. Promise! (My business is computer hardware/software, sales and service, in business since 1994, so I'm sure of this)
Yes, the front AUX is exactly what I use. If you want "easy" (actually, every method is very easy, but this is the long-term/in-use tried and true method) and only care about the front 3 channels as far as testing goes, then you can use a simple RCA cable, and 25' or so is fine, but I wouldn't go more than 50' max, and stay as close to 25' as possible.
Monoprice makes great ones and you can do the same for even less. All they do is use standard RG-6 Sat/CATV cable and put some RCA plugs on the end. I make my own for even less, but if you don't want to fool with it and don't need custom lengths, their prices cannot be beat.
You'll simply plug the mic in to your PC/Laptop (Up to 15' standard USB extension cable can be used and if you need longer than that, Monoprice again has wonderful and cheap options for amplified USB cables for much longer lengths) and then from the sound card in the same computer you'll run an RCA cable back into your pre-pro's AUX input.
That's it!
If you want access to all channels for testing (the only program that does this, for free or any reasonable amount of money at least) then you'll need a PC/Mac/Laptop with HDMI. You'll simply plug the Mic in to the USB port, same as the other example, and then run an HDMI cable from your computer to your pre-pro.
There are no other cables/connections required. Then simply download the driver from the link Jeff posted above, install it (can't mess this up - anyone can do it...Just click next next finish) and you're good to go.
I'm honestly not trying to make this sound any easier or more difficult than it is.
Jason
Originally Posted by JChin
Questions:
Before downloading V5.01 beta 10 do I need to delete the old REW version?
Not necessary, the newer version will overwrite the older version, but you will be prompted, just say YES!
After V5.01 do I still need to download ASIO4ALL (the one Jeff posted)?
Yes. Then go to REW ->Preferences->Soundcard and look for the big radio button: "ASIO Control Panel", it should be there.
So REW connection will be:
UMM-6 -> usb -> Laptop -> HDMI -> Receiver -> HDTV
Yes.
Edited by mogorf - 1/1/13 at 11:54pm
On the ASIO Control Panel click on the "+" sign to expand. It will show how many channels are available.
Cheers, Feri
Well, I'm intrigued with being able to test 8 channels, which is why I went ahead and ordered the USB mic. But with the "old" method, I could individually test front left, front right, center (setting mono signal configured as PLII Cinema), and the subs. TBH, measuring the surrounds, heights, and wides is not likely to produce very meaningful information.
Jerry
Great, but remember, and this goes for everyone reading this... You only need to install this [ASIO] IF you will be using HDMI from your computer to your Pre-Pro/AVR.
If instead you'll be hooking up an RCA cable, you will NOT need to install this.
The difference is, with HDMI and this driver, you have access to measure all 8 channels and with RCA you can only measure (easily, at least) LCR/Subs.
--J
NOTICE REGARDING USB MIC SELECTION:
I feel it important to let everyone in on a few things as there are some differences in the two options.
While this information needs to go in the new thread since folks are starting to spend their hard earned money, I didn't feel it appropriate to wait.
Please forgive the off-topic post. I'm only trying to help folks decide how to spend their money.
First, I have recommended the UMM-6 USB Mic over the Mini-DSP for a few reasons. The most important reason is that for the same price (within a few dollars) you can get a true individually calibrated Mic with 0/45/90 degree axis and Polar Response data, from a Company in the US who also has great support if needed.
However, the current beta version of REW doesn't have the same total/100% PNP support for this Mic like it has for the Mini-DSP Mic.
BOTH Mics will hook up the same way, the same minimal amount of cabling, etc, but there will be a few more settings to select and set up in your PC and in REW if you purchase the UMM-6 Mic.
For folks that want a no nonsense, easy, and 100% PNP setup to be up and running with REW in 2 minutes, as of the time of this post, you need to purchase the Mini-DSP Mic.
In fact, as of right now, the Mini-DSP Mic is the only Mic that is in stock.
You can always send the Mini-DSP Mic off to Herb at CSL and have it calibrated later, and once we get more samples of them and compare the mics and the calibration files they come with from the factory we "may" find this isn't even necessary as they "may" be close enough.
I am in talks with JohnM, the author of REW and in fact just sent him a PM over at HTShack before posting here, asking if he could/would please add the same support for the UMM-6 Mic that he has added for the Mini-DSP because quite frankly for all you can get with the UMM-6 as far as the calibration goes, and the 0/45/90 degrees plus the Polar Response data for the same price, it's a much better bargain.
However, I do understand folks with not much PC experience who are coming from Omnimic/XTZ and who want a simple/no-nonsense PNP solution may be a bit frustrated with me if they get the UMM-6 Mic and can't just plug it in and go.
I'm not trying to dissuade anyone from purchasing the UMM-6, but again, if you are going to be disappointed if you have to do anything or set anything other than plugging it in, please order the Mini-DSP!! For now, it's your only choice anyway as the UMM-6 is out of stock.
Hope I haven't confused anyone or turned anyone off of REW or the UMM-6, but I felt it necessary to offer full disclosure as to the situation as it stands at this moment.
When I hear back from JohnM I will let you all know.
While I cannot commit for him or speak for him, I don't feel it will be a big deal to add the UMM-6 to the dropdown list and make it a selectable item just as he has done for the Mini-DSP, but again, as of this moment, there is a bit (just a bit, honest) more involved in getting up and running with the UMM-6 Mic.
Thanks for listening, and again, I hope to have all this moved over to a new thread very soon and invite you all there!!
--J
I am not frightened away by the prospect of a little more effort getting the UMM-6 working with the new REW release. I like the idea of an individually-calibrated mic (like my EMM-6 fromSpectrum Labs). So, I am likely to keep my order as is for now. Since they are on back order, and since I am in no particular hurry, there is always time to change my mind as our discussions progress. (Jerry)
Regarding the new thread, here are my thoughts regarding the purpose of the thread:
- To assist existing REW users in reducing the complexity of their kits by providing guidance in implementing plug-and-play USB mics.
- To alleviate the apprehensions of those who don't use REW--it's not as difficult as it looks!
- To explore the uses and advantages of using HDMI connectivity and measuring speakers other than LCR and subs.
- To provide basic guidance for using REW measurement techniques to users of Audyssey RC, e.g. using REW to optimize speaker placements/room treatments prior to running RC, and to assess the post-calibration results.
- To provide a forum for sharing REW measurements for feedback and recommendations.
Jerry
jevansoh, are you knowledgeable on ETC measuring? That is next up for me along with decays to verify my ears making me think I need to swap some absorbers out for diffusors.
Jeff
Not Jason, but this thread provided me with some good guidance on ETC as well as Waterfalls:
http://www.avsforum.com/t/1432713/using-waterfall-and-etc-graphs-to-analyze-room-response/150#post_22551641
On my laptop, I have to plug in the HDMI lead and connect to the AVR before starting REW in order to see the multi-channel option in the ASIO control panel, or in the REW drop-downs. Give it a try.
Regards, Mike.
Sure! After re-reading what I typed, I can see how it may be a bit confusing.
Before I begin, I must re-state that I am in talks with JohnM the author of REW and as soon as I can get him a UMM-6 mic (they're on backorder right now) I believe he will put it in the drop-down list of supported/PNP mics in a new beta release.
I cannot guarantee this or speak for him, but I do feel he is responsive to this and very willing to accommodate as soon as he can get his hands on one. He's in Europe and so I have to get one and ship it to him, but will do this as soon as they are available again hopefully at the end of this month.
Now, the differences are few, but there are differences.
First, strictly speaking about setup of the two mics in REW, if you get the Mini-DSP mic, you will literally just fire up REW and in the preferences page you'll select the Mini-DSP mic as the mic you're using. At that point it will automatically ask you for the path to your calibration file that came with the mic. That's it! You're set up and ready to go.
If you get the UMM-6 mic, you will have to manually load the calibration file(s) that Herb sends you, which is literally the matter of a few extra clicks.
However, there is one more step with the UMM-6 mic (at this time). You must ALSO set the mics SPL readings (calibrate the mic) against an SPL Meter. As long as you have an SPL meter (any kind will work and the most common is a RatShack model) you're good to go.
The cool thing about the Mini-Dsp Mic is the SPL calibration data is already loaded in REW for this mic. So no SPL meter is necessary.
As long as you have an SPL meter though, it is an extremely easy/simple process and REW literally walks you through each step. When you go into preferences to set your inputs/outputs (mic/speakers) you will be reminded to calibrate the SPL and it will walk you through each and every step and offer help/a tutorial along the way with each step spelled out.
It literally takes less than five minutes to set up the UMM-6 Mic but it takes less than 5 seconds to set up the Mini-DSP mic.
In the interest of being complete, I'll also identify the differences in the mic's again.
The prices are the same within a few dollars either way.
The BIG difference is the UMM-6 Mic is hand calibrated against a specific reference mic at 0, 45, and 90 degrees by a human who knows his stuff and takes his time. He gives a detailed report of what he's done and each calibration file is separate and easy to load.
The Mini-DSP Mic is "supposedly" calibrated, but they don't specify any details other than that it is only calibrated to 0 degrees. What this means is, when taking measurements, you will point the mic towards the speaker, or in the case of taking a measurement of the L/R speakers plus sub, at the same time, you'd point it towards the center channel.
This doesn't compare well to the way we take Audyssey measurements, at 90 degrees, by pointing to the ceiling.
So... If you don't mind a few extra steps and have (or have access to) an SPL meter, the UMM-6 Mic is clearly the way to go, especially for all you get for the same price.
However, if you want quick and easy, plus if you don't want to wait, as the Mini-DSP Mic is in stock and ready to ship as of the time of this post, you can get that mic and do measurements at 0 degrees "calibrated" or you could still perform 90 degree measurements, but make sure you do NOT load the calibration file when you do that.
Condenser mics are pretty accurate except for the very low lows and very high highs most of the time, so this isn't necessarily a "huge" deal unless you need absolute accuracy or really want to know exactly what's going on.
For comparative measurements only, you cannot go wrong with either one.
You can always send the Mini-DSP Mic back to Herb at CSL at any time to have him do a calibration on it for a nominal fee, so if you do want quick-n-easy and don't want to wait, that may be a good option to get started.
Hope this helps and hope it clears things up a bit.
--Jason
Originally Posted by batpig
As an FYI, I will be installing on an 2-3 year old Netbook with a standard RCA mini jack output, so will be running mini-to-stereo RCA to my receiver's AUX IN front analog input. I'm fine with just measuring the front speakers + sub so it looks like all I need is the USB mic and I can be up and running?
Oops, forgot to answer this other question...
You will need an RCA cable and a 1/8" (3.5mm) male to 2 RCA female splitter or y-cable.
You can get these at Radio Shack for about $5.00 or Monoprice for about $1.00.
You will plug that into your line out connection on your Netbook then plug ONE RCA cable into the splitter/y-cable and the other end into the AUX connection on your AVR/Pre-Pro leaving the other RCA jack open/not used.
That's it! It's that simple. You'll be able to easily run measurements on your L/C/R speakers this way.
--J
Originally Posted by sdrucker
Originally Posted by mogorf
I'm sure many of you are aware of this thread here on AVSForum: New mic option from the good people at Minidsp
Just in case someone missed it.
Thanks, Feri. All things considered, this seems like a better option due to the built-in PNP, at least since REW support is something the MiniDSP folks are aware of. For us "laypeople", can someone explain what the practical consequences of the UMM-6 having "truly individual calibration", 0/45/90 degree axis, and Polar Response (as per jevansoh) would have over the UMIK-1, if anything, for typical use on a mic stand?
Looking forward to working with our new room assessment paradigm some time in February
(not that REW is that new, but being on the ground floor of an evolving "best practice" methodology for pre and post-Audyssey (Pro) runs is exciting - hopefully I won't "REW" the day I did this, pun intended)
Hi Stuart, just responded to your PM.
To answer your question in more detail, please see my response to Batpig a few posts up.
The short answer is...It could be a big deal.. The Mini-DSP Mic only comes with 0 degree calibration, and even that is subjective as to how accurate it is.
So if you point the mic towards the ceiling (90 degrees) to compare with the way you take your Audyssey measurements then you must not use the calibration file it comes with.
If you order the UMM-6 and have an SPL meter (to use only ONE TIME for the initial setup, so borrowing one works great in this case and is the only other step to use it in REW instead of the Mini-DSP mic where you don't need to do this step) you will get a calibration file for 0, 45, and 90 degrees and can take all kinds of different measurements/positions.
Hope this helps,
--Jason
Originally Posted by jkasanic
How do the microphones themselves compare? Assuming built-in support will come for the UMM-6 in REW, which mic would be the better choice?
These products are both pretty new, so they haven't been out long enough to compare DOA or defective rates and build quality looks to be the same.
Condenser mics in general are actually pretty accurate out of the box and great for comparative measurements (the calibration file(s) are for absolute measurements for those of us who are picky enough to want to know exactly, down to a db or so what is going on) in all but the lowest and highest frequencies.
They both come with a carrying case and are both about the same size.
There is one potential caveat with the Mini-DSP Mic though.
If you have a problem with it, it will cost more and take longer to resolve as the Mini-DSP Mic is shipped directly from Hong Kong whereas the Dayton UMM-6 Mic (similar to the one that comes with Omnimic, if not the same) ships from the USA.
As far as "better choice" goes, it depends... Like most things, you have to pick which features/options you want.
If you aren't exactly "computer literate" or are scared of new things, then get the Mini-DSP Mic.
However, if you don't mind just a few more clicks and can follow very well written tutorials/guides and also have access to an SPL Meter to use just one time, then the UMM-6 Mic is my choice as it comes with a very accurate calibration at 0, 45, and 90 degrees for the same money and ships from the US.
Hope that helps,
--J
Jason -- thanks so much for your incredible willingness to respond so thoroughly to all questions!
A quick follow-up question... I already own a basic 3.5mm mini to RCA stereo cable, like this one:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Stereo mini-jack on one end, with two RCA connections on the other end. Male to male.
Do I still need a splitter? If so, why? Do you not want the connection to be stereo?
batpig's "Denon-to-English Dictionary"
Not Jason, but REW outputs a mono signal. The splitter takes the mono feed and allows you to feed both the left and right AUX IN audio connectors on the front of the AVR so that you can measure Left + Right signals with the AVR set to stereo. With the AVR set to PLII Cinema, you can measure the center channel. And you can unplug one side of the Y-cable to measure the Left or Right channel independently.
Don't know how all this works with the HDMI cable yet... (Jerry)
Well Jerry, ...with the HDMI cable hooked up from laptop to AVR/AVP and ASIO4ALL assigned to REW the whole concept becomes much more user friendly, i.e. you can select any speaker in a multi-channel setup individually, be it a front left, a center channel or a surround speaker, all up to 8 channels. I'm already there with my REW setup, I can send out a test signal from REW Generator to any speaker at will. Moreover, I can select "any speaker + sub" in the same above setting.
Edited by mogorf - Yesterday at 12:01 am
Originally Posted by kbarnes701
Isn’t it important to measure the combined output of the main speakers plus sub? That is what we hear when we listen. I'm not challenging you, Sanjay - just asking. Hopefully, this is the sort of thing that will be explained/discussed in the new REW thread.
I should have clarified: by 2 channels, I meant (for example) L+R simultaneously. If it is important to know how those channels interact, why don't room correction systems measure and correct for the interaction rather than each speaker? Notice that Audyssey does this for the interaction of a pair of subs but not a pair of speakers.
Sanjay
You're very welcome, BP. I only wish I could respond more quickly. I know what it's like getting excited about something and having to wait on an answer.
I'm going to try to do better and rearrange a few things where I can get on this thread earlier each day while others are still awake and more actively participating which will hopefully reduce the time between questions directed towards me and my answers.
That splitter would only work if you had a male to female RCA cable.
I recommend one that has the same 3.5mm plug but instead of 2 RCA Male plugs it's 2 RCA Female jacks so you can use a standard male-to-male RCA cable.
You only want to use ONE RCA cable from this jack to your AVR/Pre-Pro because the signal is mono.
I hate to complicate things this early on, but... "IF" you wish to run a test on both speakers and subs at the same time to measure how everything is playing together once you're all done configuring Audyssey, with room treatments, etc to see the final response, then at the Pre-Pro end, where you plug the one cable into your AUX input, you can get another Y-Adapter which will have One Female RCA jack to TWO RCA Male Plugs to plug into both the Left and Right on your Pre-Pro.
That's how I have mine set up, FYI.
Hope this helps, sorry for the delayed response, and hopefully I didn't confuse you any more.
--J
Well Jerry, ...with the HDMI cable hooked up from laptop to AVR/AVP and ASIO4ALL assigned to REW the whole concept becomes much more user friendly, i.e. you can select any speaker in a multi-channel setup individually, be it a front left, a center channel or a surround speaker, all up to 8 channels. I'm already there with my REW setup, I can send out a test signal from REW Generator to any speaker at will. Moreover, I can select "any speaker + sub" in the same above setting. (Feri)
YES!
This truly does simplify things so greatly, i actually recommend this type of setup if at all possible.
Not only is this the simplest setup and a true plug-n-play setup, but it's much more powerful, in being able to measure every channel.
You literally only need the USB Mic plugged in and one HDMI cable plugged in from your computer to your AVR/Pre-Pro and that's it.
No splitters, no non-sense.
Totally recommended,
--J
You should always measure L + Sub, then R + Sub, and overlay them to make sure they're the same. If the response differs by much, you have issues that you need to resolve either via speaker/listening position placement/movement or via room treatments.
This should be done with Audyssey OFF.
Then, when all done, and with Audyssey turned back on, it's good to do a "Final check" with L+R+Subs.
Center+Sub by itself is also good, but shouldn't be combined with L/R or L+R+C at the same time.
Does that make sense??
Will go into more detail in the new thread...
--J
Originally Posted by Theresa
One of the drawbacks of REW IMHO is the requirement of an SPL meter in addition to a measuring mic.
You only need this "One Time" though for any/all mics except for the new Mini-DSP UMIK Mic we've been discussing.
The Mini-DSP Mic does NOT require this. That's one of the things that make it plug and play.
Hopefully soon, the same will go for the UMM-6 Mic, but for now you do need to calibrate the SPL with an SPL Meter just once when first setting up REW.
--J
