I know there are threads, articles all over the web, but would like some assurance if at all possible.
With the smaller sub I had before this Klipsh RW-12D, I had it in the corner, it worked quite well, the bass did not sound localized to any one spot, it filled up the area quite well. Now with this 12D, it sound great in the corner, but you can tell its comming from the left hand side if you pay attention to it.
I started moving my sub around last night, replaying a few songs, and the first tripod encounter as it comes out of the ground in war of the worlds.
I moved my sub around quite a bit playing a test tone and found that on the inside of my front left speaker sounded best, right beside my entertainment stand that sits below my TV.
So as I started listeing to all this content, the bass did sound more tight, it blended well with the speakers making it seem like there was no sub in a particular spot at all, but im not sure if I like the sound. I wanna say theres more detailed sound now that comes out of the sub now that its sitting more or less in frotn of me, not sure if I'm supposed to hear that detail and not sure I like it.
