AVS › AVS Forum › Audio › Receivers, Amps, and Processors › best receiver up to $1000
post #1 of 4
i have a brand new onkyo 818 that i am probably going to sell due to the 24 fps bug
what should i get to replace it ?
post #2 of 4
post #3 of 4
never used XT32 before and the receivers that have it are over my budget.
what do u recommend?
i am willing to go refurb but prefer new
any chances onkyo will come thru and fix the bug?
thanks
post #4 of 4
Ah .. then you never ran Audyssey on the 818, got it. Then you may want to consider one of the Denon CI models (review post #2 in the Denon AVR-XX13 Owner's thread linked in my sig to see a comparison of the features offered on each model) or the Marantz 5007 or 6007 all of which use Audyssey MultEQ XT.
