AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Subwoofer cable wall plate
post #1 of 6
I'm buying the wall plates for the new home I'm building. I will have a 7.2 system in our 1st floor livingroom. I am getting a 7.2 - 2 gang wall plate, this plate has connections for 2 subs. My question is what type of plate do I use at the other end? (the end where the sub will actually be in the room) I need the rear of the plate to have threaded coax cable type connection and then the front needs RCA connecion.
I'm buying my wire and plates from monoprice.com. Thanx.
post #2 of 6
http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-50-10835-/50-10835
post #3 of 6
^^^ Thanx... Duh, I never thought of buying a blank plate and putting the correct connector in it. I was looking for plates already made up. I will use this link. Thanx again.
post #4 of 6
You could also buy a plate with a BNC connector on it; that is what I would do.
post #5 of 6
Why? Then you would need a F connector on the back, then a BNC to RCA adapter in the front.
post #6 of 6
Here's what I bought and it should work. I couldn't find a single RCA connector for my sub so I got this:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042502&p_id=2999&seq=1&format=2
