The 2.8's surface itself seems fairly robust and smooth enough to take soft cloth, mild soap and water. Problem is, and I now have about 4 small ones after 4 years, when you do that the touched up area now looks a bit brighter than the untouched area all around it, with probably some degree of airborne residue residing after a number of years. Tiny specs from insects' waste and trying to swipe the occasional cricket off the screen and having the wrong angle with the towell swipe and smushing a bit. They clean up but on a bright white background if you know where they are.......they start to bug the crap out of you. Plus, when the spot is wet and drying it really scares the bleep out of you that it is going to wind up looking like that.
I have read it is possible to use a lot of water and I guess quickly as possible, but consistently, you start somewhere and just go for it. Across the top? Back and forth moving downward? What material & soap did you use? How often do you rinse it and how wet? "Light" amount of the soap mixed in the water? If you've been even with this..... I (think) I have read it dries and looks like new. But how very scary to make the decision to try it. Especially since 2.8 is no longer available.
Any success stories out there? Anyone repeat it more than once..... and your "system" is outstanding, even if you do say so yourself?
