Hi,
I would appreciate some help. I recently built a home, ~3 years ago, an installed a levetron structured media enclosure in a closet. I'm just getting around to wiring it. The enclosure measures ~14" across. I'm looking for a blank patch panel that fits my enclosure. All of the patch panels I have found on the internet seem to be 19" which obviously doesn't work for my situation. I've done a pretty exhaustive search but I seem to be missing something.
A secondary question....
I intend to use the blank patch panel to fit with F connectors to feed video to the different rooms in my home. My current setup is a HD receiver in the living room with SD receiver in my bedroom. The receivers operate independently of one another (I can watch separate broadcast in each room). I have recently upgraded to the TV in the bedroom to HD and will soon be upgrading my receiver to HD as well. What kind of multi-switch will I need to feed 7 rooms with 2-3 different receptions which will allow for some expansion in the future.
Thanks for the help!
IM
IM
