I have an imported LG BH200. I've had it for some time and recently come across a small problem. The problem being it doesn't seem to want to download new firmware updates.
My player is currently on SW Version: BH02100330A. It checks for updates and has found one - BH02100401A.
I press OK to download the new update and I then get a message saying "Download in progress". The front panel display says "Download".
I then get a message saying "Download is complete. Do you want to update? SW Version: BH02100401A". I press "OK" and the on screen massage says "Updating", the front panel says "Extract".
Once this has done, I get an on-screen message saying "Download complete. Shutting down in 5 seconds". The player does indeed shut down automatically.
I then turn the player back on, go into the update menu and this is where things get annoying. Because instead of downloading the new firmware update, I get a message telling me I'm currently on the old software update (BH02100330A). And it tells me a new update is found... But it's the same update I just downloaded before the machine automatically switched itself off! The same firmware update it told me had just downloaded.
The machines driver version is 0702.
Has anyone else had any problems with this? I'm in the UK so can't send it to LG because it's out America.
Any help and advise would be great.
