AVS › AVS Forum › Video Components › Home Theater Computers › Android Player for DVD content with dvd menu
post #1 of 11
Hello,
is there any Player for android that play correctly DVD (with dvd menu) in form VIDEO_TS or ISO?
I tried many players (VLC, BSPlayer, MX Player, MoBo Player...) and nothing...
I need it for playing on the road via internet from my Home Media Server.
Thank you very much for your tips and help.
Peter
post #2 of 11
perhaps Cyberlink's PowerDVD mobile?
post #3 of 11
Thanks for your tip. I have tried it, but unfortunately it doesnot work for DVD on my HTC Desire HD.
post #4 of 11
XBMC is close. According to their forums it will play VOB files directly. I haven't had any luck with playing ISO files and there appear to be some issues with playing VIDEO_TS folders as well.
post #5 of 11
Maybe close, but now XBMC android still dont work with ISO or VIDEO_TS with menu...
I have not find any android player till now...
post #6 of 11
Yes and its free "Wondershare Player" It Plays Video_ts files as a single video. Wondershare player works great., just copy the whole DVD Folder to your sd card and it will find it and play it as a single video just like a normal DVD. Wondershare will play all your video formats but also have a ton of media outlets attached ie.. Hulu, Youtube, Espn, Aol, Ted, ect.... so its an online and offline media source.
REMEMBER IF YOU ARE PUTTING THE VIDEO ON AN EXTERNAL SD CARD YOU MUST ADD THAT DESTINATION FILE TO THE SETTING OR IT WON"T FIND IT. Wondershare is "Settings-Scan Multimedia file folder-media folder", then just click Add Folder and choose you destination folder ie /storage/extSdCard/Videos---- your media will be found under LIBRARY tab then on the LOCAL tab .
You can read the descriptions on the link below and get better info.
https://play.google.com/store/apps/details?id=com.wondershare.player&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS53b25kZXJzaGFyZS5wbGF5ZXIiXQ..
Here the description if you don't want to use the link....
Wondershare Player is an all-in-one Video Player & Video Discovery to "Discover latest videos to watch online & offline", no need for other players or codecs.
Highlights:
* Discover Latest Online Videos
We pick and recommend you the most recent and hottest videos from other entertaining sites. You can view and search videos from various platforms, such as YouTube, Vevo and Hulu freely. It is a better way to search, discover and watch Movies, TV full episodes, hottest Music Videos and funny videos clips within one app.
Notice: Non-US countries are not allowed to visit Hulu.com as its region restriction.
* Watch Videos Later
Sometimes, you may be interrupted suddenly when you are enjoying a movie; or frustrated by the network connection. Now, don't be upset, you can add it in the "Watch Later" Queue, to watch it later without a data plan. Wondershare Player can download streaming videos from CNN, NY Times, Ted Talk, NASA TV, Funny or Die.
* Best Video Player for Android
Wondershare Player plays smoothly without any problem no matter the codec or format.
It supports all the video and audio formats, including FLV, AVI, MKV, WMV, MOV, RM, RMVB, ASF, M2TS, MP3, WMA, AAC, FLAC, M2TS, VOB, F4V, 3GP, etc.
It supports subtitles embedded video files, supports subtitles as SubStation Alpha(.ssa/.ass), SAMI(.smi/.sami), SubRip(.srt), MicroDVD(.sub/.txt), SubViewer2.0(.sub), MPL2(.mpl/.txt), PowerDivX(.psb/.txt), TMPlayer(.txt).
It plays DVD folders from SD card directly with DVD menu navigation.
It supports continuous playback and can automatically remember your last played position.
Edited by youngjr - 1/22/13 at 12:19am
post #7 of 11
yeah,i think so, now XBMC android still dont work with ISO or VIDEO_TS with menu.thank you 1.gif
post #8 of 11
Highlights:
Thank you very much for your tip, I will try it. Is possible play DVD with DVD content also thru sharing (for example thru BubbleUPnP Server and BubbleUPnP Player)?
post #9 of 11
I have never tried or used the BubleUPnP Server, however I use "mediaserver" and link to my PS3 and that works great.
post #10 of 11
I am not sure I understand you well. Do you use this android player with your mediaserver on your PS3?
post #11 of 11
not exactly, I use the mediaserver app on my android and am able to play the videos across my ps3 that way, it was kinda off subject of using the player but I just gathered that you wanted to play the dvd thru sharing with your question and that is the only sharing device I have hooked to my tv. I am fairly new to android my work only used Blackberry until almost a year ago so I might have just miss understood your question or just not know what I am talking about..
