post #31 of 31
Originally Posted by bobsilver View Post
The box is a straight up Google TV so connecting a 1 tb drive should be ok but I havnt tried one. Regarding playback of your files I am certain you will find an app on the Google Play Store to do what you want. It comes with Avia media installed. I use Plex which would handle what you want but Plex is designed for much more then home video. Also you may want to reconisder hooking a drive to it and just sharing a drive from a NAS or networked computer. This is much more flexible and prefered. You can attch your 1TB drive to a computer and share it which the Neo can read from. That is how mine operate.
The remote buttons cannot be re-purposed. But check if there is an update for HBO for GTV. That may be all you need.
Good luck.
Bob
