AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › OFFICIAL Samsung Smart TV "Evolution Kit" Thread
OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 45
post #1321 of 1474
Thought I might add, I finally just pulled the batteries from the fancy new remote, and my problem has yet to reoccur. Kinda bums me, as it is a nice remote, but the other two work fine.
post #1322 of 1474
Originally Posted by armerius29 View Post
Will this reduce the input lag on the ES7000? to a point where i will be able to play without GAME MODE ON? cause lets be real... it looks like ass with game mode on...
i doubt it. i play ps3 games on normal mode and it's ok enough for me.
post #1323 of 1474
i finally replaced the batteries with some GP ultra ones and it works a lot better now.
you have to setup the remote for using some HT or amp and the settop-box if you have one, after i did that the random weird things it did dissapeared.
it works via bluetooth so there might be something else causing interference with the signal. some babyphones or wireless cam systems tend to screw up the signal.
post #1324 of 1474
Thx for the tip. I've seen sub-par batteries do strange things with electronics before, but might not have thought to try replacing the provided generics, had you not posted. You are right about random bluetooth signals doing things, as eventually, even after I had pulled the bad batts, I did see oddbal behavior - but nothing like when that remote was powered up. I'm going to try your suggestions. Thx
post #1325 of 1474
gta v , the last of us etc looks good on normal mode... game mode off..but the god damn latency kills me..thats why i ask. it depends on the game..try to play red dead redemption without game mode..and the latency its terrible..the same with gta v. thats why i ask if the input lag its reduced by the evo kit or not.
post #1326 of 1474
i have no problem with gta v though..  but to answer your question.. its not. due to the fact the evokit works together with the tv's mainboard and its hdmi interface which is causing the delay of minimum 20ms as well as the screen itself which has 12ms-18ms delay depending on screentype.
post #1327 of 1474
so pretty much there is no diference at all for gaming...with or without the evo?
post #1328 of 1474
there is a little , but not enough to satisfy your needs.
post #1329 of 1474
Originally Posted by cseck View Post
Can anybody help with my problem or has anybody else had any problems with there bluetooth dropping out/turning off???
I have the same problem on my 3rd kit. Replaced kits twice because of a picture problem that turned out to be my UN60ES8000 motherboard. First two kits had no Bluetooth problem. Still waiting for Samsung to fix this issue.
post #1330 of 1474
you tried putting new batteries in it and reprogram the thing ?
post #1331 of 1474
can u let me know please if u get this sorted and how u or they fix it as my bluetooth is playing up again with controller not working again...
post #1332 of 1474
yes change the batteries. after not too long time having the controller do weird stuff it's gonna display a window on the tv telling the batteries are allmost empty eventually.
post #1333 of 1474
I already changed the batteries a few days ago as like u said i got a little box on tv telling me the batteries were nearly dead and then a couple of days after changing the batteries my bluetooth started acting up again...
post #1334 of 1474
did you reprogram the thing after ?  i.e. pressing the connect button on it and do setup again ? i had no trouble after doing this steps.
post #1335 of 1474
I didn't reprogram it i just pushed the connect/pair button on back of controller and controller connects too tv but after a couple of hours of not using controller it won't work unless i turn tv off then on again...
post #1336 of 1474
Well it's not just the remote having problems. It's also my Samsung Bluetooth keyboard. The keyboard works fine with TV if I remove the kit. The menu items related to Bluetooth go gray when it drops out too.
post #1337 of 1474
Same as with mine too, so i tried without evo kit too but the bluetooth will drop out/turn off after couple of hours aswell without the kit too and like u said the options too add new device mouse/keyboard will be greyed out too...
post #1338 of 1474
Looks like the new Evolution kit will be pretty much like the current edition was, but without the new Smart TV interface. Lots of emphasis on voice and gesture control - along with a new remote (again?) If you haven't gotten the kit yet then you might want to wait for the new one, but so far I don't see any compelling features -- but we shall see!!
post #1339 of 1474
mm must be the US version firmware then, mine doesn't drop out it just doesn't react sometimes for a second or so when i press buttons to fast after eachother.
post #1340 of 1474
Link please?
Here's a peek at the 2014 remote. Pebble shaped and includes motion controls like LG's magic remote
http://www.engadget.com/2013/12/31/samsung-smart-control-tv-remote-ces-2104/
post #1341 of 1474
Cnet's article about the new remote: Smaller and actually includes DVR controls
http://ces.cnet.com/8301-35303_1-57616556/samsung-smart-control-features-gestures-more-buttons/?part=rss&tag=feed&subj=
I see no reason why a new hub/remote upgrade would not be a part of the new evolution kit. Without that what else would there really be to offer? New features would be nice but the 2013 kit was all about the new hub so I'm expecting the same here: A new Smart Hub/ quad core/ & the new remote. And perhaps a new gimmicky feature or two if we're lucky
post #1342 of 1474
yug,, i don't like the new remote design.. the 2013 one is more sophisticated and it has a powerbutton for the settop which i use for my amp. the 2013 looks different then mine also
post #1343 of 1474
any news about the evolution kit 2014?
post #1344 of 1474
in netherlands its comming around may. usually it comes after the new models tv from samsung come out.
post #1345 of 1474
Do you know anything about the features of the 2014 kit?
post #1346 of 1474
not more then is noted in gamermwm's link above
post #1347 of 1474
I want upgraded Motion Judder Canceler with better frame interpolation and less artifacts and also a better 3D algorithm with less crosstalk/ ghosting. Couldn't care less about an upgraded Smart Hub (totally happy with what I have already in the F8500).
Edited by Watcher12 - 1/6/14 at 10:53pm
post #1348 of 1474
there is no rumor or anything about the next evo kit in CES 2014..so i guess there wont be one this year?
post #1349 of 1474
That would be a shame. Was a big part of why I bought the F8500 over the VT60.
post #1350 of 1474
All they mentioned at CES was the future evolution kits for their 4K tv's they will be releasing. But if they don't support their recent tv's with them (as they said they would) they will have a lot of unhappy customers
