Hi All, new to the forum, but looking for help on setting up my sub. I live in an apartment before so never had one, but excited to finally get some bass living in a house.
Fronts L/R: Paradigm Monitor 7 v.6
Center: Paradigm CC-190 v.6
Rear Surround L/R: Paradigm ADP-190 v.5
Sub: Klipsch Sub12 HG Synergy Series
Receiver: Onkyo TX-SR605
Primarily using it for the following in priority order Movies (Blu-ray/DVD), Gaming (PS3), Music (Digital), TV (Roku). Running everything in via HDMI, except the music which is coming from a hardline digital SPDIF cable. Also running full copper speaker wire to everything, and have a "subwoofer" cable for the Klipsch. Everything is in a partially submerged basement (half above/below ground). Plenty of space in the main room down there.
On the back of my Receiver I've got a single sub line out that says Pre-Out Subwoofer. If I run the cable from there to the Sub, I see two "in" connections on the sub, one says "Left/LFE" and the other says "Right". I've been told to use the LFE input so have the cable there now.
It also has banana type plugs for High Level In and High Level Out. Guessing I'll leave those alone? Also 2 dials for Gain, Lowpass, and a switch for 180 or Phase. Thoughts on where I should start with those or any setting I need to go back and make on my receiver?
